Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 08-21-2005, 08:38 PM
caprice1987 caprice1987 is offline
what are the biggest tires you can put on the rear of a caprice?
Just wondering how big a tire I can put on my 1987 caprice (stock car no mods) with a 15x8 rim?
I'm thinking about going with 275/60/15's if they'll fit and like 245/60/15's on the front with a 15x7 rim. Think it'll work?
I would really appreciate some feed back don't want to spend the money and not have them work
Old 08-21-2005, 08:49 PM
CD Smalley CD Smalley is offline
Re: what are the biggest tires you can put on the rear of a caprice?
Yup it will work. That's exactly what I have on my car. I think a 255/60/15 would give a better look up front though....
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 09-22-2005, 09:32 PM
Bob Ash Bob Ash is offline
Send a message via ICQ to Bob Ash
I've got 275s in rear and 225s in front. It's maybe too sloped, 245s and 275s or 225s and 255s shlould look better.
Old 11-08-2005, 04:58 PM
Cyrix_2k's Avatar
Cyrix_2k Cyrix_2k is offline
Alright... 255/60/15's should work for front and rear right? I think I might go with these or 245/60/15's all the way around.
1996 BMW 318i Convertible
1989 Caprice Brougham - 305 V8, TH-2004r - FOR SOLD!!!
Old 11-08-2005, 08:12 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
I used to run 255/60/15s on my car all around. Using the stock rims, they fit just fine although a 255 is on the upper end of what will fit a 7" wheel. They looked good too, had so much grip that I wore them out after about 15-20k miles.
Old 11-08-2005, 08:39 PM
BZR77CHEVY BZR77CHEVY is offline
I'm running 255/60 15's n 15x8 vette rallys all the way around... No clearance problems with the car at stock ride height that I can tell, The car corners beautifully and they fit the wells perfect. aside from the looks and handling Two bonuses that I have found: 1) Since they are all the same you can still rotate them, and 2) The tire height is close to stock diameter which keeps the roll out close therefore no speedometer calabration is needed.
Old 11-15-2005, 10:01 PM
Cyrix_2k's Avatar
I just got my new wheels put on. They're Dayton S/R P255/60/R15's on 15x7 ARE rims (late 80's GNX style) and they fit beautifully. However, I think I need to drop my car an inch or so to make them look right. As far feel goes, I immediatly noticed that the car handled MUCH better and it stiffened the ride up some. It also won't squeal at all when I floor it (damn 305)...
Old 12-03-2005, 03:57 PM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
Re: Re: what are the biggest tires you can put on the rear of a caprice?
ive had 31 x 10/50's truck tires on the back of one before
was running 15x8" ralley wheels
sometimes the outer sidewall would rub a little bit on the wheel house lip, like on quick turns
but not major
i coulda trimmed up the lips for clearance
i need to find a set for my 84
good luck
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
