Go Back   Automotive Forums Car Chat > Dodge > Daytona
Old 08-21-2005, 06:21 PM
heavyhalf heavyhalf is offline
1990 daytona tranny problems
my car will not shift into 3rd gear it always stays in 2nd.....what is wrong with it. it is a 4 speed overdrive tranny with a 3L v6. and how come my tach works sometimes and sometimes it does not work. i here a strange noise coming from the back of my car kinda like a grinding noise.
Old 08-22-2005, 01:08 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: 1990 daytona tranny problems
from what you're describing sounds like a bad output speed sensor, though seems odd that your tach would intermittently work it makes sense that your speedometer wouldn't work. The grinding noise sounds like you have bad wheel bearings in the back.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 08-22-2005, 07:54 PM
the speedometer works. and the grinding noise is coming from the back and when it is not moving it is still making the noise
Old 08-22-2005, 10:22 PM
you might have a bad solenoid pack, thus not allowing your transmission to stay in "limp mode" though, like I said before you tach not working doesn't make sense to me. The grinding, if it's doing it all the time even could be a fuel pump that ready to crap out on you.
Old 09-19-2005, 10:01 PM
Boogieman142 Boogieman142 is offline
Send a message via AIM to Boogieman142 Send a message via MSN to Boogieman142 Send a message via Yahoo to Boogieman142
once again, another a604 in fail-safe mode. I'm guessing that you just did a tranny fluid change. You didn't make sure that it was full before you shifted it through the speeds. There is an air bubble in the tranny, don't go replacing parts cause its useless. You need to get the air out and have the code cleared by a drb II scan tool. After this you will be fine.
Old 09-22-2005, 10:22 AM
weaverm weaverm is offline
I've got a '91 Daytona 2.2L Turbo automatic (assume 4-speed). The car will sometimes, but not always, shift into 4th. I have not changed the transmission fluid but occassionally have to add some. My speedometer works intermittently, but I assume that's an independent speed sensor problem. Any idea if the transmission shifting problem is caused by a similar problem as the '90 described above or something different?
Old 09-26-2005, 10:49 PM
there's air in the system, get it out and get the code cleared.
Old 10-18-2005, 11:08 PM
yeah i got it fixed. it was a little wire near the tranny sensor. it works like new. it shifts through gears nice and smooth I ma thinking of keeping the car now. but I still want a 1994 cutlass supreme 2 dr.
Old 10-19-2005, 04:11 PM
Cutlass supreme huh, they are junk, made by GM. I had one and it was my last GM product that i'll ever buy. They have too many problems.
Old 10-19-2005, 07:02 PM
so what I like them
Old 10-20-2005, 02:00 AM
Just be prepared to put a lot of parts into it. Your daytona is more reliable then a cutlass supreme.
