Old 08-21-2005, 06:03 PM
tword99 tword99 is offline
Send a message via Yahoo to tword99
died now wont start
was driving slowed down rounded corner tries to resume speed, vehicle cut off as if turning off by key. started once moved several feet cut off again. had to tow home. Replaced fuel pump, filter.
codes said egr valve and map sensor, rpl those. ICM still look good. 2 mos. old. Long as I spray gas in it van will run. I did clean a lot of garbage out throttle body, the injectors were barely dripping not close to spray pattern. Also rpl dis. ign. mod. need insight on injectors
Rpl fuel pump, fuel filter, ign mod, fuel cut off, egr valve, map sensor, Icm, injectors in throttle body Any one got ideas
Help!!!!
Old 08-22-2005, 09:13 AM
Aqua Angel's Avatar
Aqua Angel Aqua Angel is offline
Send a message via ICQ to Aqua Angel Send a message via AIM to Aqua Angel Send a message via MSN to Aqua Angel Send a message via Yahoo to Aqua Angel
Re: died now wont start
Have you tried to replace the Fuel pump in the tank? next time try banging the bottom of the tank with a hammer, if your van starts after? well your fuel pump is going.
I had that sick joke happened to me too while i was working and thank god for the hammer. the van started right up, but soon after? propane. no need for a pump anymore.
93, Chevy Astro van, Saphire Blue, Led tail light.
looking for:
Euro clear corner lights and Billet grill "chrome" and a good shinny 5 spoke rims and a disc brake rear differential
Old 08-24-2005, 09:02 PM
characksel characksel is offline
I had the same problem a year ago. Fuel pump went, and also blew a fuseat the same time. They link the windows, and fuel pump on the same fuse on my Astro. Its the 3rd large fuse on the left under the hood, from the front. I now have a fuse/breaker in it place.
Old 09-05-2005, 07:32 PM
Re: Re: died now wont start
It's ALIVE!!!! again the ign. module went out along with a bad fuel and air filter caused it to quit. wouldnt start back after rpl those, because the fuel line got twisted, couldnt see it because the line was in a sleeve that hid the problem. When I took the inlet line loose from throttle body could tell the line was pinched.
