Go Back   Automotive Forums Car Chat > Toyota > Avalon/Pronard
Old 08-21-2005, 04:53 PM
amauryz amauryz is offline
Question 96 Toyota Avalon Check Engine Light
My 96 Toyo Avalon check engine light came on. I borrowed a tool to read the computer code and it detected code P0135 - Sensor Heater - Bank 1 Sensor 1 - 02 Sensor Heater Circuit malfunction? The autopart clerk tells me I need to go to the dealer, because he does not sell the part in question. Can someone please tell me what I need to do to correct this problem. Thanks +++
Old 08-23-2005, 08:06 PM
Joe W Joe W is offline
Re: 96 Toyota Avalon Check Engine Light
It is probably the O2 sensor on that bank.
Old 08-26-2005, 01:16 AM
Toysrme's Avatar
Toysrme Toysrme is offline
AF - Advisor
Send a message via ICQ to Toysrme Send a message via AIM to Toysrme Send a message via Yahoo to Toysrme
Cool
That's because they didn't know anything.
o2 sensor's normally only last 90-100,000 miles, so it is more than likely time for your to replace yours anyway.
Start by resetting the ECU (Pull the EFI fuse for a second & replace it).
If the code returns (It should) replace the rear(bank1) oxygen sensor. You'll get hit with a nice price, being a more complicated 4 wire type.
Gonna take a hit. You've got 4 wire o2 sensors. Normally go for $60-90usd.
Toysrme257th - AIM about anything, anytime; including v6 turbos.
World's second ES 300/3vz-fe Turbo.
Old 08-31-2005, 09:56 PM
toyomechanic421 toyomechanic421 is offline
just make sure u get the right part. air/ fuel sensor means before cat, o2 sensor means after the cat. Bank 1 is the head closest to the firewall.And sensor 1 means the first sensor after the cat. use some kind of rust gone or what ever u can cause being heated and cooled so many times makes the threads fragile, if it siezes then u must replace the hole pipe. clear the code by removing the efi fuse if you dont have a scan tool.
Old 09-01-2005, 12:52 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Use your VIN to get the part number from the Toyota parts department, even if you don't buy it there. Then you will get the correct sensor.
Bank 1 Sensor 1 is the sensor next to the head and in front of the cat converter for the head nearest the firewall. Not after the cat.
See the diagram on page one of:
http://www.autoshop101.com/forms/h37.pdf
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 11-09-2005, 06:52 PM
RTM98607 RTM98607 is offline
Unhappy Reading the check engine light
I noticed that you read the diagnostics for your car. I have a '98 Toyota Avalon with a 'check engine' light on. I assi=ume it is the O2 sensor, but I'd like to read it from the diagnostics connection. It is not the standard OBD2, but rather a round connector. Where do I get the connector? Does the connector work with a OBD2 reader?
Thanks!
Mike
Old 11-09-2005, 09:03 PM
Brian R.'s Avatar
Resident Chemist
See if this helps:
http://www.autoshop101.com/forms/h27.pdf
http://www.off-road.com/toyota/tech/codes/
The connector sounds like an OBDI connector. Check the end of the autoshop article.
Your car should be OBDII compliant. Check under the dash - driver side by the center console for an OBDII connector.
Old 02-20-2006, 10:31 AM
mooseketer mooseketer is offline
What brand scanned did you use?
I have a '98 avalon and would like to buy a scanner but would like to get the correct scanner the first time around?
Is the plug in the '98 a OBDI or and OBDII?
Old 02-20-2006, 10:32 AM
Re: Reading the check engine light
Hi Mike,
What did you find out about the '98 Avalon scanner? I'm looking to buy a scanner for my '98 Avalon but don't know which one to buy. Any suggestions?
Old 03-01-2006, 12:15 AM
Ant OBD2 scannerwill work, make sure you locate the correct connecter under the dash.
