Old 08-21-2005, 03:41 PM
Sh0rtThr0w Sh0rtThr0w is offline
Send a message via AIM to Sh0rtThr0w
install RPM gauge
I bought a sunpro 2-5/8in. tach for my 97 5spd cavy. I was told that I needed to know what wire to tap into. So I'm asking if anyone knows the right wire/ or has a wiring diagram. Also if the wattage isnt correct I would need an adapter. Is this true?
Thankx Guys
Old 08-24-2005, 12:01 PM
Dark Drake Dark Drake is offline
Re: install RPM gauge
do a search on google ive seen it but dont remember where it is
Old 09-01-2005, 06:34 PM
quake61's Avatar
quake61 quake61 is offline
Thankx Guys
hey short i have a 2000 cavalier and have also a sun pro tach
u need a sun pro adapter for that car
when u bought the tach it came with a list of cars and models
look for ur 97 cavy and it will tell u if it needs an adapter
if it needs it ( which i think it will) it will tell u what color of wires
to tap in the ignition coil
is easy with the adapter and tach info
if u need more info lemme know and ill be happy to tell u all about it
Old 09-01-2005, 08:50 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
theres 2 ways you can do this, you can get a tach adaptor, you can get any brand, its not like one will work better then the other, the one i have is from rksport, with the adaptor you splice it into 2 wires going into your coil pack, and at the other end of the adaptor is the wire you connect to your tach for the "signal"
if you dont wanna buy an adaptor, you can splice into a wire coming directly out of your PCM, you will need a tach that you can set to 2 cylinders for this though since you will only get half your reading this way, im not exactly which wire it is but im sure you can find out by doing an extensive search through these forums
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
