Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX > Technical
Technical Discuss Engine, Suspension, Drivetrain, and all other technical issues here.
Old 08-21-2005, 03:09 PM
zacremacle's Avatar
zacremacle zacremacle is offline
Ground Problem
Can someone post up pics on how a s14 should be grounded because my new one i cant get a good ground on it and the ground wires look different then the ones that were on my old s14. can someone post up a diagram or pics of where the ground wires are supposed to be grounded to. THanks
Old 08-21-2005, 03:14 PM
Waltz's Avatar
Waltz Waltz is offline
Re: Ground Problem
....... wich ground wire are you talking about ???
Battery , radio , tps , ecu ????? be specific...
Old 08-21-2005, 04:19 PM
zacremacle's Avatar
Re: Ground Problem
The battery.
Old 08-21-2005, 04:48 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Re: Ground Problem
Ground it to a large chassis bolt. Test resistance using a multimeter. Should be <1ohmk. Sand all contact points well too. Expose bare metal.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 08-21-2005, 07:59 PM
Waltz's Avatar
Re: Ground Problem
thats right , althought it should not read 1 ohm it should read continuity
Old 08-21-2005, 10:10 PM
zacremacle's Avatar
Re: Ground Problem
Alright. because i dont know what had happened to the factory gronund but it was grounded to the battery tray and i knew that was not right. I cant remember where my old s14 was grounded ill try and fix it tomm after i get off work. Ill take a pic too so you guys can see how it is grounded.
Old 08-21-2005, 11:06 PM
240SX Guy
Re: Ground Problem
There is always some resistance. Electricty, water, air, anything. Always some energy lost.
-Cory
12.6@122mph
Old 08-26-2005, 11:15 PM
slideways...'s Avatar
slideways... slideways... is offline
Re: Ground Problem
once you connect it put voltmeter leads from the chassis next to where the bolt is(but not on the actual connection) to the pos terminal. you should get about .2 V less than battery voltage. any more of a drop than that says bad connection
and it could have been grounded to the battery tray if the tray is metal and directly connected to the body. my car has the neg cable bolted on the batt. tray, then to the frame
the chassis and the block and the head should all be grounded through the chassis then to the neg terminal.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
