Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 08-21-2005, 03:04 PM
doodad's Avatar
doodad doodad is offline
Send a message via AIM to doodad Send a message via Yahoo to doodad
Autozone scan result, help please!!!
hi guys,
l just came back from autozone. they scanned and here is the result.
TROUBLECODE OBDII (ALPHA) P CODE
TROUBLESHOOTING P1870
Transmission Automatic 4-wheel Drive Indicator
(Lamp) Circuit Short To Battery
Transmission Mechanical Transfer Case 4x4
Switch Circuit Short Battery
yeah guys, that is the result but l didn't understand anything... could you please explain what does that mean please??
Thank you...
Old 08-21-2005, 06:18 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Autozone scan result, help please!!!
Originally Posted by doodad
hi guys,
Thank you...
Autozone's scanners don't translate GM manufacturer specific DTC error codes too well. I don't think you have 4 wheel drive in your Firebird.
If you are really having auto trans problems and its a bonifide odb-ii code as far as P1870 and triggering a SES light, it generally means Transmission Component Slipping. The PCM monitors torque convertor clutch (TCC) slip speed by calculating the difference bewteen engine speed and drive output. It's detecting excessive slip related to the torque convertor.
Possibilities are the torque convertor, valve body related such as stuck 1-2 or 3-4 upshift solenoids or the TCC regulator valve, burnt or damaged 2nd, 3rd or 4th clutch plates, etc.
Timeslip 08/12/06
AF Community Guidelines
Old 08-21-2005, 07:19 PM
doodad's Avatar
l do not think my car has 4 wheel drive either. also, l am gonna take my car back to dealership tuesday, could you guys please let me know what could the problem be excatly?
thank you....
Old 08-21-2005, 07:49 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Did you check your fluid level?
P1870
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 08-21-2005, 07:56 PM
BNaylor's Avatar
Re: Re: Autozone scan result, help please!!!
thank you....
Are you actually experiencing problems like erratic shifting, delayed shifts, up shifting only after letting off the gas or over-revving?
A common problem with the 4L60E tranny was the TCC regulator valve on the valve body. Sonnex has a TCC regulator valve kit that should correct the problem. Transgo has performance shift kits that will probably take care of the problem. On my son's '96 Trans Am we wound up putting in a Transgo kit and replacing the torque convertor with an aftermarket. He spent too much time at the dragstrip and sooner or later you got to pay the Piper.
Thrasher CAI, DHP v1.0 PCM, SLP Headers,
3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 72mm TB,
TB spacer, MSD 8.5mm wires, Autolite 103,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
1/4 ET: 13.210 sec. @ 104.490 mph
0 - 60 ft: 1.945 sec.
Timeslip 08/12/06
Old 08-22-2005, 03:56 AM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
You do know all Fbodies were rear wheel drive right?
Old 08-22-2005, 08:54 AM
BNaylor's Avatar
Does that mean when you do a burn out that the smoke comes off the rear tires versus the front? lol.
Last time I checked a 4L60E tranny was for GM rear wheel drive only and I'm quite sure the guy that needs the help knows he's got rear wheel drive without insulting his intelligence.
Timeslip 08/12/06
Old 08-22-2005, 09:22 AM
doodad's Avatar
hi guys,
first of all, thanks for your replies. sure l know that my car has rear wheel drive.. just firehawks are all wheel drive l guess, l read this somewhere on internet.. l just do not know so many things about engine.. also l cannot burn my car.. when l move immediately, l hit the accelerator all the way down, bu the car doesn't burd. it just moves real fast. it s automototic transmission.
by the way, formula LT1 l haven't checked fluied.
now l will go and check it..
thanks
Old 08-22-2005, 09:27 AM
FormulaLT1's Avatar
Fight the powwa!!!
Firehawk's or any other F-body's never left the assembly line with anything other than rear wheel drive. So where ever you read that. Never pay that site any attention again cause its full of crap and low fluid levels causes slipping so it could very well be a super easy fix. Good luck and let us know how it turns out.
John
Old 08-22-2005, 09:28 AM
doodad's Avatar
hey bnaylor3400,
l am sorry l forgot to answer your question.. when my car changes gear, it is jumping to front.. l always hit my heas to my seat. especially from 1 gear to second gear.. ok my car is areal strong car but, it shouldn't be like that l guess.. l mean it is not changing the gears smoothly.. do you think that is normal for formula superchargers or something is wrong??
Thank you..
Old 08-22-2005, 09:42 AM
BNaylor's Avatar
I'd go with FormulaLT1's suggestion first and then let us know.
Timeslip 08/12/06
Old 08-22-2005, 09:47 AM
doodad's Avatar
hi FormulaLT1,
thank you very much for information about firehawk also.. l remembered now, it was on autotrader.com l saw it there. all wheel drive, blah blah.. anyway l just wanna solve my girls problem..
l juest bought it.. even l haven't payed the first bill yet.. and l drove it just 200 miles. ( l bought it 1 month ago)
by the way FormulaLT1 l just opened the hood, and l couldn't see fluid place for transmission, there is just one for brake. could you please let me know what should l do step by step so l can do it right away and let you know??
thank you
Old 08-22-2005, 09:50 AM
doodad's Avatar
hi bnayloer3400,
l will do everybody's suggestions, because you guys knows everthing better than me.. and l tried to do it but l couldnt find the fluid place l am sorry..
Old 08-22-2005, 10:09 AM
FormulaLT1's Avatar
Fight the powwa!!!
The dipstick to the tranny should be passenger side rear of engine. Running along the firewall. With the vehicle level, start the car put it in each gear then leave running in park and pull the dipstick, wipe it off and then note the temp of the fluid and it will be marked cool/warm/hot on the stick and should be within that range within what temp it is. If it is below the cool mark it most definetly is low and that is whats most likely causing the slipping.
Old 08-22-2005, 10:17 AM
doodad's Avatar
thank you formula LT1, now l will check it.. by th way, l have a cellphone with camera and l always take pics.. if you go to supercharger folder, you will see my engine pics.. l took them 10 mins ago.. and after l check that dipstick, l will take pic. again and you will see on the pic, what level it has.. l will be back soon.
thank you..
Closed Thread
