Old 08-21-2005, 03:00 PM
Riceboy891's Avatar
Riceboy891 Riceboy891 is offline
obd conversion
I am making an obd0-1 conversion harness to put my sohc zc in my 90 hatch. I got the female obd0 plugs from an old ecu i had. But i need the male ends from an obd1. Where can i get these(Manufacturers?part numbers? websites?) i need the grey ones in the pic. http://www.import-ss.com/custom/OBD0-OBD1.gif
1990 Civic HB
DOHC ZC *RIP*
SOHC OBD1 ZC
ZC Tranny
P06 ECU
Stage 1 Clutch
I/H/E
B&M Short Shifter
14" Integra Wheels
KYB AGX Shocks/Tein Springs
"yeah but it has most all of that hp and torque though the entire rpm range, where as a honda, have to be revving high enough that only dogs can hear your motor to make numbers" -TheSilentChamber
Old 08-21-2005, 04:03 PM
SSJSubgeta's Avatar
SSJSubgeta SSJSubgeta is offline
Send a message via AIM to SSJSubgeta
Re: obd conversion
you can get them from either
A junk yard (prices vary).......or
a web site, http://www.rywire.com/ they got everything you need to save you time, and the hassle, i dont know if its a good deal, but to many people it is to many its not, up to you.....GL
Old 08-22-2005, 03:41 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
Re: obd conversion
rywire harness is the easiest way to do it, pretty cheap and simple and will save some wiring headaches along the way.
I use it.
2002 Acura TL Type S
1991 Honda Crx Si
Old 08-23-2005, 07:49 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: obd conversion
i used one of jasons conversion harness in my swap, good stuff
Team Lonely Drivers
