Old 08-21-2005, 02:47 PM
fat2ii fat2ii is offline
Question turn signals
I have a 92 grand am the turn signals do not work check all the bulbs and fuses replace the switch but they still dont work need help badly???
Old 08-22-2005, 12:23 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: turn signals
sounds like a relay/flasher. have u tried the hazard lights? they work?
Old 08-22-2005, 06:19 AM
gmack221's Avatar
gmack221 gmack221 is offline
Replace your flasher, its cheap and should be your problem, don't assume its good if your 4-way-flashers work, my 95 GA has 2 flashers, one for the 4-ways & one for the turn signals. The flasher should be located near the base of the steering column, if your 4 ways work turn them on and replace the flasher not making noise!
Old 08-25-2005, 07:21 PM
where is the relay on 92 grand am at
Old 08-25-2005, 09:07 PM
gmack221's Avatar
Re: turn signals
on my 95 grand am se there are 3 relays under the hood, they are on the passanger side, near the windshield. Hope your are in the same spot, if not maybe someone else can help you.
Old 08-26-2005, 07:10 PM
skibum1111 skibum1111 is offline
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
Flasher relays are under the dash on the driver's side, clustered with the chime module in a little bracket. Listen under the dash with the door open, find the annoying sound and the flasher unit should be right there.
Old 08-27-2005, 03:46 PM
Re: turn signals
replace the relay still not working there must be a short somewhere looks like i will just have to take in thanks for the help
Old 08-28-2005, 07:37 AM
scott181 scott181 is offline
Send a message via Yahoo to scott181
Re: Re: turn signals
I had a similar problem with my 94 after I had taken
the steering coloum apart. It was turned just a bit
when I put it back together and moved the hazard
switch just slightly. Not enough to turn them on,
but it made the turn signals inop. Try wiggling the
hazzard swithch a couple of times and making sure
it is all the way off. Hope this helps.
Old 08-31-2005, 05:32 PM
Re: Re: Re: turn signals
i give that a try
Old 09-22-2005, 05:14 PM
Re: turn signals
hey don’t know if anyone is still looking at this but I fix my car found a second relay hidden behind the stereo replaced it and all is well now take care boys and girls I will be back to ask for more help I am sure later
