Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 08-21-2005, 01:47 PM
crabby760 crabby760 is offline
no fuel help
last nite i was driving and i was almost home and my car died... and it wont start up again....
i noticed the fuel pump isnt making the normal noise..... u know when you turn the key to ignition it makes like a buzin noise that when the fuel pump turns on rite?...
well its not doing that anymore....
wat could be the problem....
Old 08-21-2005, 04:31 PM
i checked my starter fuses and my fuel pump fuse.... they are good...
so i have no clue what could be wrong..?
Old 08-21-2005, 11:10 PM
took fuel pump out of car..... ran direct power to it from the battery... and it spun and shot gas out at me... so i know the fuel pump is working...
and all the fuses are good...
i have no clue what is wrong?
Old 08-21-2005, 11:35 PM
97integrals's Avatar
97integrals 97integrals is offline
Check for voltage at the pump connector with the ignition on if there is no voltage, which I would assume there isn't, check the pgm-fi relay. If the relay checks ok then there is probably a damaged wire somewhere.
Old 08-22-2005, 08:06 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
Re: no fuel help
main relay....
2002 Acura TL Type S
1991 Honda Crx Si
Old 08-22-2005, 08:09 PM
where is the main relay on a 96-98 civic ex..
cannot find it anywhere....
Old 08-22-2005, 09:18 PM
Re: no fuel help
It is on the passenger side. Remove the glove box and it will be a large black (I think) relay on the right side once the glove box is removed. It will say PGM-FI somewhere on it.
Old 08-22-2005, 10:17 PM
didnt check that yet... but we did run direct power to the pump and the car still did not start.....
now i get no spark.... wtf ahhhhhhh
Old 08-22-2005, 11:58 PM
i get no spark... and ran direct power to fuel pump.... have no idea what is going on...
can someone help me with anything......
Old 08-23-2005, 06:44 PM
Smoghog Smoghog is offline
Re: no fuel help
So let's see. No power to the fuel pump. So the circut for the pump go's from the battery to the relay and from the relay to the pump and then ground.
It's not the pump, and it's not the battery. 2 down 2 to go.
Wiring and the relay
Did you check to see if you had voltage to the pump?
Did you check to see if you had voltage to the relay?
Your relay should have two power sources one from the ignition switch or computer
and one from the battery. You need to check them both while the engine is cranking.
So let's add the ignition switch/computer it is #3
As for your no spark now. Your fuel pump relay might provide power to other things (I don't know, don't ask)It might not. Also, there should be a safety measure built in. If you do not have a rpm signal you will not get power to the fuel pump relay. This kills the fuel pump in case of an accident. After all you don't need fuel if the motor is not spinning.
As you can see it is dangerous to bypass the relay This is a bad thing.
So to finalize check
Signal from dist. for RPM
Power to relay. Ignition switch/Computer and Battery
Likely it is the relay. However if your computer is not getting an RPM signal it will not provide power to the relay and or the coil.
I hope this will get you somewhat "UN"crabby
SH
Old 08-24-2005, 07:58 AM
can not find the relay for the fuel pump....
dont know what you mean by check the distributor what do you want me to check on it?
i've tried swapping out ecu's and it still doesn't start so i dont think its a ecu problem....
the ignition works ............
Old 08-24-2005, 08:01 AM
i was told relay was behind the glove box on a 96 up civic ex... if so how do i take the glove box off ?????
also when i find the relay how do i check if its good or bad?
Old 08-24-2005, 08:03 AM
and my car does crank over.... cranks and cranks and cranks... but it just gets no spark or no fuel........ thanks for all the help.... still need more though guys... please help me
Old 08-24-2005, 10:35 PM
fixed the problem.... a wire under the steering column... was loose just reconnected it and it started rite up.... i dont know what that wire was but it did the trick.... lol...
thanks everyone
