Old 08-21-2005, 01:04 PM
Harryn Harryn is offline
Gas smell
I have a 97 Chevy Blazer 4 dr with a 4.3 Vortec. 145000 KM (80000 miles)
I now smell gas ???
Just for a bit of history.
The fuel gage had not worked properly for about 2 years. That finally got to me so I decided to fix this. Dropped the tank and replaced the fuel sending/pump unit ($400.00). When doing this I did not know that there was a vent valve on top at the other end of the tank. I just thought that it was stubborn so a yank broke this and I had to replace this as well. All went in okay and all was fine for about 2 tank fulls. Now I smell gas after a few minutes of driving. You do not notice it unless you are driving slowly or at a stop with the engine hot.
There are no fuel leaks!! There are no cracks in any hoses that I can see
Old 08-21-2005, 02:18 PM
drdd's Avatar
drdd drdd is offline
Re: Gas smell
Do you overfill or top-off at the pump?
I now smell gas ???
Old 08-21-2005, 03:19 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Gas smell
vent is stuck or you are overfilling your tank which causes raw fuel to get into the evap canister.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 08-21-2005, 03:40 PM
Re: Gas smell
At the pump I just go to the next dollar.
If there is raw gas in the evap cannister how do I deal with that? New vent valve should not be stuck!!
Old 08-21-2005, 03:41 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Gas smell
Check your vent and take a whiff near your gas cap and check for gas vapours.
Old 08-21-2005, 04:37 PM
drdd's Avatar
Re: Re: Gas smell
stop topping off. the automatic cutoff is there for a reason.
Old 08-21-2005, 05:11 PM
Re: Gas smell
I have taken the cannister out and there is a bit of gas in there. The line that is marked tank had about two tablespoons worth of gas. Can I dump it and blow it out and reinstall??? or do I need a new one.
Old 08-21-2005, 11:28 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Gas smell
You should be able too reinstall it.
If there was fluid in the canister, you filled it up more than topping it off to the nearest dollar.
The vent for the EVAP is only 1-2 inches down the neck.
Old 08-22-2005, 09:20 AM
Hey Thanks a bunch for the info.
Most times I go to a self serve station and just round off to the nearest dollar. The last fill I went to a full serve, not only that the attendant dropped the cap.
Drained/dried the Canister, I replaced the gas cap as well and now all is good!
Thanks
Old 08-22-2005, 09:23 AM
BlazerLT's Avatar
AF -Advisor
Re: Gas smell
Thanks
SahWEET!
