1997 Jeep Grand Cherokee keyless remote
Does anyone have programming instructions for the keyless entry remote for a 1997 Jeep Grand Cherokee? ... or know where I can find them on the web.
Re: 1997 Jeep Grand Cherokee keyless remote
Up to 4 transmitters can be programmed into the receiver at any given time. All transmitters to be used on a vehicle must be programmed during this procedure. (1) Open the driver’s door and leave it open during the programming process. (2) Move the mechanical door lock lever on the driver’s door to the LOCK position. (3) Insert the ignition key and turn it to the RUN position. (Do not start the vehicle.) (4) After turning the ignition key to the Run position aim the transmitter at the receiver and press the LOCK (right) button for 5 seconds. Once the receiver accepts the programming the door will unlock. Move to Step 5 If you have more than one transmitter you are going to use with this vehicle. Move to Step 6 If only one Jeep remote is used. (5) If additional transmitters are to be used on the vehicle each must be programmed during the programming sequence. (Up to 4 transmitters can be programmed to a vehicle) To program additional transmitters: Return the mechanical door lock lever on the driver’s door to the LOCK position and aim the next transmitter at the receiver and press the LOCK (right) button for 5 seconds. Again when the receiver accepts the programming the door will unlock. Repeat step 5 until all transmitters have been programmed. (6) When all transmitters have been programmed to the receiver, the ignition must be turned off and back on within 20 seconds after programming the last transmitter. When this is done, only the transmitters that were programmed. TAKEN FROM www.jeepremotes.com BESTOF LUCK! |
Re: Re: 1997 Jeep Grand Cherokee keyless remote
I've already tried that one with no luck.
Thanks for the reply though. C'YA |
Re: Re: Re: 1997 Jeep Grand Cherokee keyless remote
CABMAN |
Les, is right you will have to take it to the stealership to get it reprogrammed. I think starting in 96 the keyless entry FOBs had to be programed by the stealership.
