Old 08-21-2005, 09:38 AM
daddy0_4 daddy0_4 is offline
'93 G.V. 3.3 a/c,rad. fan not getting power
a/c "just stopped working" the other day. comp not getting power. hot wired, comp came on started cooling,low pressure ok then comp belt started squeling, probably because rad fan not comming on. ckd and fan needs to be replaced(hard to spin) bot also not getting power to 4 pin connector at fan. PLEASE HELP!!! its hot here in fla. THANKS
Old 08-21-2005, 07:08 PM
Re: '93 G.V. 3.3 a/c,rad. fan not getting power
found the problem: found a burnt fuse link in the harness next to the drivers side strut tower. replaced with a fuse. now a/c comp. engages. all thats left is to replace the bad fan motor.
