Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
View Poll Results: BOOT LIGHT WHERE IS IT?
I THINK IT DOES NOT HAVE ONE 0 0%
IM NEW TO THIS 1 100.00%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
Old 08-21-2005, 09:35 AM
ROSSD898 ROSSD898 is offline
Unhappy Help Low Fuel Flow To Engine
Hi I Have A Camry 1988 Sedan, I Am Lookng To Find Where The Fuel Pump Is If There Is One And The Fuel Filter.i Have Looked Every Where. Thanks For Your Help
Old 08-21-2005, 11:25 AM
Toysrme's Avatar
Toysrme Toysrme is offline
AF - Advisor
Send a message via ICQ to Toysrme Send a message via AIM to Toysrme Send a message via Yahoo to Toysrme
Cool
Why do you think you have low fuel flow? That's a fairly rare condition.
The pump is in the top of the tank, the fuel filter is roughly under the air hose. Driver's side, close to the wheel well, low.
Toysrme257th - AIM about anything, anytime; including v6 turbos.
World's second ES 300/3vz-fe Turbo.
Old 08-21-2005, 12:01 PM
Re: Help Low Fuel Flow To Engine
I INSPECTED THE FUEL LINE FROM TANK AND IT IS ONLY LITTLE DROPS OF FUEL COMING THROUGH, IT STARTS ONLY IF I PUT THE ACCELERATOR FLAT DOWN PEDAL,.WHEN I LET GO IT DIES OUT IMMEDIATLY, THIS PROBLEM WAS ONLY LITTLE NOW ITS BAD NO FUEL FLOW DEFINITELY.THANKS FOR YOUR QUICK REPLY I APPRECIATE IT
Old 08-21-2005, 12:02 PM
Thank You For Help
Old 08-21-2005, 12:16 PM
Toysrme's Avatar
AF - Advisor
Cool
The fuel pump won't even turn on until the engine begins sucking air through the Air-flow meter.
With the key in the ON position, reach into the air filter box & push the air-flow meter's flap open. You should then get the fuel pump to activate.
At any rate, change the fuel filter & go from there.
