Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 08-21-2005, 06:46 AM
stressfree stressfree is offline
90 dodge 3.9 no power at coil
same old song wont start.no spark at plug.no spark at coil.no voltage at coil.did the 5 sec voltage test.o volts.tested the asr there working.wires look good.whats with that pickup coil in the dist.on fords when they go bad it wont start.
Old 08-23-2005, 07:26 PM
Re: 90 dodge 3.9 no power at coil
checked coil on other machine works good.would that hal sensor kill the power to the coil.
Old 09-12-2005, 09:31 PM
catfish263 catfish263 is offline
same problem
the signal to fire the coil comes from the asd relay.the relay receives signals from the crankshaft and camshaft position sensors then supplies battery voltage to the coil.Open the hood reach in and turn the key to run and listen carefully for the relay to pull in.if the relay doesn't pull in two thing--bad relay or bad sensors
Old 09-21-2005, 08:02 AM
89ltd 89ltd is offline
its probably the hall effect pickup coil in the dis, you won't get any spark activity or power to the coil if it is not working. They hardly ever give a fault code.
