Water on passenger floor
1990 Geo Metro 1.0 - During the heat of the day with the AC on full blast -- I noticed water pouring out from under the dash on the passenger side - carpet is soaked -- when not using air no leak --
Heater core ? If it is where to buy I ordered a manual today - I would like to do this myself Thanks to all |
Probably not the core. These cars are bad about collecting debris in the plenums that house the evaporator and core. There is a drain tube that exits the lower right firewall. It's most likely clogged. If it is clogged the water produced by the evaporator will leak on the floor.
Re: Water on passenger floor
You are right not the core -- i am going to blow out the hose -- but there is another problem -- what I gwuess to be the plenum and where it meets the evaporator? there is a foam like gasket that is rotted -- that is where the water comes from - is there an easy fix for this? |
