Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 08-21-2005, 03:48 AM
89ZCCivic's Avatar
89ZCCivic 89ZCCivic is offline
stiff turns
i need some help with my 89 honda civic hb. the problem is that the steering wheel get really stiff and it makes it hard to turn .a while back ,maybe about 3 months ago i replaced the cv boots and the steering rod boots also .both the steering rod boots were in really bad shape they were split in 3.it seems like there was some sored of red grease in the s.rods .when i whent to buy the boots i asked the dude from auto zone to tell me what kind of grease to put on the s rod,he said it dosent really need any . so i was ok .but then i was like shit maybe thats why my damm streering wheel is really hard when turning .so what i did was i put some of the grease that i used on the cv boots.that helped for about a week then it whent back to being stiff .ok so do i need to use grease for streering. do i have to replace the axels .could this also be the reaso that my car does wheel hop even though ive already filled the motor mounts with silicon. 1 more thing what are the lower and upper strut bars for anyways? any help is appriciated
Old 08-21-2005, 11:42 AM
94PreludeJDM's Avatar
94PreludeJDM 94PreludeJDM is offline
Re: stiff turns
I'm not sure about the problem you're having, but the lower and upper strut bars (or sway bars) are used to improve handling. They link together your suspension and make your chasis more rigid, which results in less body roll, among other things, when cornering.
Old 08-21-2005, 01:52 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Re: Re: stiff turns
That is incorrect for strut-tie bars. They DO NOT reduce body roll in any way. They DO stiffen up the chassis, but that's nothing stiffer springs and shocks can't already do anyways. IMO, they are just eye candy and nothing more. Unless your suspension is set up right, you won't notice their benifits much if any.
Swaybars on the otherhand DO reduce body roll and are the most recommended first time suspension upgrade.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 08-21-2005, 09:53 PM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
Re: stiff turns
I have a 1991 Civic and they do not come with power steering. But after you replaced all those parts did you get an alignment? I noticed when I set my toe to 0 front and rear the car was easier to turn.
But just get the car moving. Once it's moving the steering wheel requires less effort to turn.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 08-22-2005, 12:02 AM
BullShifter's Avatar
Re: Re: stiff turns
Is the steering wheel hard to turn with the wheels off the ground?
Old 08-22-2005, 08:27 PM
89ZCCivic's Avatar
Re: stiff turns
ui never tried turning with the wheels off the ground .but when i drive thru a dirt road the streering gets smooth
