whining noise coming from front end
i have a 94 cavalier 2.2 with 105k on it. i am getting a whining noise out of the passenger side front. it sounds like i have big tires on it, like a 4x4 or something. i am getting no vibrations and it stops doing it when i turn to the right. it gets louder with speed and the rpms dont change anything. where do i start
check the wheel bearing.
jack it up and check for lateral play. Grab the tire by the top and bottom. pull on the top and push on bottom and visa versa. If there is any play that is most 90% your problem. |
Re: whining noise coming from front end
i thought lateral play would indicate a bad ball joint
Re: Re: whining noise coming from front end
but the way I explained it checks for play in the wheel bearing. It's prolly not called lateral movement. another quick check is to pull the tire in and out I believe. |
Sounds like a bad wheel bearing. I bet the sound becomes real evident after you pass 25Mph on a straight?
Interesting, how when I had a 94 ramped and spun the wheels, there was no indication from the bad bearing. After removal and inspection it behaved like a bad bearing. |
