clutch (?) help
ok, not exactly mitsu related, but I need some help. So I'm driving, my friend was following and he loses teh ability to shift gears.
background: He has a 99 maxima, intake and aftermarket clutch (2 years?). We were sitting in my driveway, and I noticed lots of liquid under his car. He had been chillin for 20 mins, so I figured AC purge (water). We drive 10 miles. Chill for an hour, drive 10 miles back. As we approach our destination, he loses the ability to shift gears. He stops, and can't get into or out of gear. I hop in the car, his clutch is worthless...fully depresssed, I can't get into ANY gear. Weird thing is, after fooling with it for a bit, he gets it into reverse, however....it doesn't stall when he doesn't hit a thing. NO gas, nothing, and it doesn't stall!?! Then it again was a bitch to get outta gear. Now we can't get it into gear at all. There is complete resistance when you try and shift. I tried again, and couldn't get it into ANY gear....and when I tried 5th...it grinded. I'm thinking he is seriously leaking (empty) clutch fluid....but I was hoping for some more knowledgable people to comment. Thanks in advance, Geoff ps. It's 4am, quite dark, so I really can't see anything. But tomorrow I need to get this car moving!
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
Re: clutch (?) help
I was gonna' say clutch fluid myself, I think musashi had a leaky clutch, I'm sure he'd be willing to help ya.
Georgey on the subject of midget beastiality pornos Quote:
R.I.P Andy, you will be missed by all. |
Re: clutch (?) help
Yeah, he was outta clutch fluid. I added fluid, found the leak, bled the clutch, and it's working now. Thanks.
Re: clutch (?) help
outta clutch fluid in which cylinder? master or slave? and what was the leak? did the solution involve duck tape?
93 3000GT base K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2 coming soon: adj. cam gears | bi-xenon HID retrofit |
Re: clutch (?) help
Haha, master cylinder was completely dry. The leak was one of the tubes/hoses. The connection was loose and fluid had apparently been leaking from it. The solution didn't involve duck tape...but bleeding the clutch did
