Old 08-21-2005, 12:20 AM
mitsu_eclipse95gst's Avatar
mitsu_eclipse95gst mitsu_eclipse95gst is offline
Question Tb
Has any one ever had there TB spring not close your TB all the way? Mine idles fine at start up but once i hit the gas it will rev @ 1900-3200 I can push the TB closed and it is all good. Spring feels real loose also. Have any of you had this happen? How did you fix it?
1990 Mitsubishi Eclipse GSX
1995 Mitsubishi Eclipse GS-T (SOLD)
2002 VW Jetta 1.8T
Old 08-21-2005, 04:14 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Re: Tb
Did you unwind the springs in it at any time?
Or has the inner or outer one broke?
Aside from there being tension on the throttle body shaft...does it pivot freely?
Have you done a boost leak test to see if it is leaking out the shaft seals?
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 08-21-2005, 04:29 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Tb
That is usually caused by a dirty throttle body. A good cleaning will usually take care of it. Could also be from the plate not being installed on center after a seal change, if you have done that recently. .
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 08-21-2005, 05:24 PM
Re: Tb
I have not done anything with it.. No boost leak test yet.. and none of the ears are broken.
2002 VW Jetta 1.8T
Old 08-22-2005, 03:44 AM
AF - Advisor
Re: Tb
A good cleaning would be the next step. The vfaqs had a good writeup on it.
Kevin Jewer
Old 08-22-2005, 06:32 AM
Re: Tb
Ok i Just cleaned the crap out of it! Still being held open. I have ALL brand new sensors. I have also sprayed cleaner down the protective seal of the cable while moving in and out (THANT BITCH WAS DIRTY) Could it be that gay ass wax pellet? I think i am just going to plug the FIAV
2002 VW Jetta 1.8T
