Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 08-20-2005, 08:21 PM
jmdcool76 jmdcool76 is offline
transmission problem
when i come to a stop light then start to go when i press on the gas and i start to go my rpms rush up to 3000 rpms but it doesn't accelerate what is the problem?
Old 08-20-2005, 08:37 PM
ctesla's Avatar
ctesla ctesla is offline
Re: transmission problem
I take it this is an automatic???
welcome to AF.
check your fluid level.
does this only occur once hot? intermittantly? ALL the time?
could be something as minor as the filter is clogged, or a modulator giving out, to something as major as you've got 120+K of hard miles on the trans and nothing has ever been done, so the whole thing needs an overhaul.
post back with more specifics: did it just start? how and when?
how many miles? have you jumped a curb lately? might be a loose vacuum lead...
as much info will help.
thanks,
chris
(but definitely check fluid first; if it's low, it would cause a rev, then a HARD shift kick into gear)
Old 08-20-2005, 08:42 PM
ok
it happens alot it only has 76k on it just had new brakes put on all around new muffler and cat converter it has new dist. cap and rotor new spark plugs and wires its a 85 6cyl.
Old 08-21-2005, 09:48 PM
84fiero123's Avatar
84fiero123 84fiero123 is offline
listen to jdmcool76
all it takes for these autos is to be 1 pint low to make it shift funny, any more than that and you could have sever trans damage.
technology is great when it works
but one big pain in the ass when it doesn't
Detroit Iron Rules, all the rest are just toys!
