Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 08-20-2005, 08:14 PM
alphalanos alphalanos is offline
GSR tranny
So ive decided on buying a GSR B18C around may or june. Im ordering from Hmotors online and plan on converting my AT 96 civic Lx to 5spd with the supplied tranny. Is the tranny swap too difficult for the weekend mechanic? I assume it involves cutting and probably welding new brackets.
96 EJ6. Future home of boosted B18C1.
Old 08-21-2005, 05:57 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: GSR tranny
http://www.honda-tech.com/zerothread?id=1316692
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 08-28-2005, 06:25 PM
94tegRS's Avatar
94tegRS 94tegRS is offline
Re: GSR tranny
I did mine in a day and a half, lots of hours spent not sleeping though, the only thing I cut/welded was the mount on the car itself because I wanted to use the OEM manual trans mount from my parts car. 180 bucks could have gotten me a bolt on part form hasport. also where the torque-rod/shift-rod setup bolts to the tunnel, had to drill those 2 holes and use nut and bolt. after you bolt it pup I recommend tack-welding the nuts to the tunnel so when you evewr need to remove it it will be so much easier. there is also somw wiring but I took the complete dash harness from my parts car. the clutch master cylinders hole was already there and just plugged up. bolt holes for the hangers for the clutch hardline are already in place as well. it isnt really ever a hard project, just an involved one with lots of little details you have to deal with.
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
