| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
7 bolt 6 bolt?
my buddy has a 95 gst fwd with a blown motor (7 bolt right). will a 6 bolt engine bolt right up or is it easier to get a 7 bolt
What is a 6-bolt engine?
What is a 7-bolt engine? A 6-bolt engine is one that has a 6-bolt flywheel - that is, there are 6 bolts holding the flywheel to the crankshaft. A 7-bolt motor has 7 bolts there. Along with the flywheel change, there are many other internal changes between the two engines. The crankshafts are different sizes, as are the rods and crankshaft seals. 6-bolt motors have 'big' rods, while 7-bolt engines have 'small' rods. The journal and bearing widths different, although the bearing diameters are the same. There may also be other changes between the two engines, and the parts are not interchangeable. I would get a 6 bolt, it will slide in just fine. Good Luck!! John
Eagalicious's 1997 Eagle Talon Tsi AWD K&N FIPK 3rd gen lifters, installed Apexi Turbo Timer w/harness!!! now to install Eibach Springs coming soon 3" turbo back with straight pipe. The muffler was the wrong one Manual BC 1G BoV The rest is stock but not for LONG!!
Re: 7 bolt 6 bolt?
small modifications required. many, many, many pages of information online about the swap.
DSM geek |
Re: 7 bolt 6 bolt?
This may help you. Good luck
http://www.dsm.org/archives/1999/11/...08.txt/37.html http://www.roadraceengineering.com/2...torinstall.htm
Diego Fontán Eclipse GS-t ==>AWD 12.12 @ 113.xxmph 60' 1.76 ![]() Check My GS-T ==> AWD project car's video: http://cssteam.com/gstx.wmv At the track: http://videos.streetfire.net/video/aad4c670-6066-44d5-b6f6-c04346cb8407.htm |
