Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 08-20-2005, 06:39 PM
DJPsystems DJPsystems is offline
fuel pump disconect
On a 98 camry 4 cyl. I am trying to find a way to disable the fuel pump to do a fuel injection cleaning. Is there a fuel pump relay or fuse? I can't seem to find any.
Old 08-21-2005, 01:17 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: fuel pump disconect
Normally, there is an access panel under the rear seat for the fuel pump power connection. Use that power connection to disable the pump. After you disable the pump, start and idle the engine until it quits to relieve the pressure in the fuel lines.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 08-21-2005, 12:01 PM
Toysrme's Avatar
Toysrme Toysrme is offline
AF - Advisor
Send a message via ICQ to Toysrme Send a message via AIM to Toysrme Send a message via Yahoo to Toysrme
Cool
Take the gas cap off, it will relieve 90% of the pressure.
Toysrme257th - AIM about anything, anytime; including v6 turbos.
World's second ES 300/3vz-fe Turbo.
Old 08-24-2005, 12:52 PM
Brian R.'s Avatar
Resident Chemist
I don't believe that removing the cap from the fuel tank will have any affect. The high pressure fuel line is not vented into the tank. The fuel in the high-pressure line may bleed off into the tank over time, but removing the cap won't relieve the high pressure as found immediately after shut-off. The fuel line is supposed to hold pressure of 21 psi or greater for 5 minutes after engine shut-off - otherwise the pressure regulator or pump is defective.
My recommended procedure posted above was from the Toyota service manual.
http://i16.photobucket.com/albums/b8/rogersb/Fuel1.jpg
http://i16.photobucket.com/albums/b8/rogersb/Fuel2.jpg
