Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX > Technical
Technical Discuss Engine, Suspension, Drivetrain, and all other technical issues here.
Old 08-20-2005, 04:59 PM
lkdsign lkdsign is offline
Question Hedlamp won't retract
I have a 1991 Nissan 240SX hatchback which recently developed a "tick" in which the driver's headlamp would not always retract. Both go up but only one goes down. It used to go down intermittently but now it won't go down at all, and I have to retract it manually. Obviously the motor works or it would not even go up, or so I thought. Any idea what I should look for. Bare in mind I have owned it since 1993, and NO aftermarket mods have been made.
Old 08-20-2005, 06:18 PM
Waltz's Avatar
Waltz Waltz is offline
Post Re: Hedlamp won't retract
humm , i actually have this problem with mine , tricky thing is , the wiring for the headlamp goes throught the radio and all lighting equipement , mine will just close when i shut off engine (shows how messed up it can get)
Bad grounds on either motor or switchs must be looked at , voltmeter and ohmmeter is a cheap and most usefull tool to get to check power and grounds to your motor/switch/grounds.
My best advice is , get to any school where they teach auto mechanics and ask to get your cars lighting wiring diagram, they'll gladly give it to you. i have it on paper , but unfortunatly i have no scanner .
best of luck bub
Old 08-20-2005, 07:47 PM
240SXSlideStar's Avatar
240SXSlideStar 240SXSlideStar is offline
How can you make the lights go down when you just turnoff the headlights? lol I have to turn off the parking lights also to get them to go down. :-S Sorry for jacking the thread.
-Jonathan
JDM Racing Motors inc
Montreal, Canada
www.jdmracingmotors.com
Old 08-20-2005, 07:50 PM
Waltz's Avatar
read your wiring schematics , you'll figure it out
(note , my park lights must be off too in order for my beams to go down)
Old 08-20-2005, 07:58 PM
Re: Re: Hedlamp won't retract
That much I knew... symantics
Old 08-20-2005, 07:59 PM
best of luck bub
So did you figure yours out?
Old 08-20-2005, 08:27 PM
Waltz's Avatar
never had time to do it and sa long as they close when i turn off the engine im happy.
But i have the wiring diagram at home , if you want i'll try and find someone with a scanner so u can get it
hit me back on the subject
Old 08-20-2005, 08:34 PM
That would be grand. Can't hurt to know where all the grounds are and stuff at least. i was thinking it might be some kind of relay or such too. You can email to [email protected]
Thanks in advance.
Old 08-20-2005, 08:38 PM
Waltz's Avatar
could easily be , relay box for the headlight motor is right under the air filter box *if you still have one that is* like i said , if u have an ohmmeter , relays are real easy to check.
Usualy are 4 pins , and they go by pair , if 2 outta 2 pair's have continuity , its a good sign that the problem isnt from there (then again , it might be , but only in some rare case's)
anyhow , ill try and find those diagram's
Old 08-28-2005, 04:59 PM
Tims_240's Avatar
Tims_240 Tims_240 is offline
you probably just need a new relay, its in the fuse box, its one of the bigger ones. it happened to me before.
-tim
mods list: t3/t04e, iap oil lines, iap i-c piping, xspower i-c, z32 mafs, enthalpy tuned ecu, 615cc injectors, s14 tomei fuel pump, blitz DD bov, tial 38mm w/g, BD exhuast mani./downpipe, Spec StageIII clutch .
.s13 power.
power estimate at ~ 270 whp @ 11 psi.
Old 08-28-2005, 05:01 PM
-tim
That would be excellent, is it in the main fuse box or some auxiliary one?
Tim
Old 08-28-2005, 11:35 PM
Tims_240's Avatar
when you look under your hood its to the left right next to your battery.
.s13 power.
Tims_240's Avatar
its one of the big ones in the right of the fuse box. let me know if you have any trouble.
tim
.s13 power.
