Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 08-20-2005, 03:38 PM
mmatasci mmatasci is offline
Problem Code connectors 96 T-bird
I was wondering is if the connector for engine problem "self-tests" is the very small plug in the left corner in front of the shock tower.
Old 08-21-2005, 01:01 AM
Jim Adams Jim Adams is offline
usually it says diagnostics on it and it should be a grey case with about 5 wires in it,,and yes it is on the passenger side behind the shock tower,,,you have to use a meter and hook it up with a jumper going to a ground to do it yourself with out a scanner go to this link and it shows you how to hook it up to a volt meter and the slef test input and output to get your codes. http://autorepair.about.com/library/...bl-dtcs-60.htm
This link will give you a list of the codes and if you scroll down it will show you how to self test. Good Luck1
