Old 08-20-2005, 10:57 AM
jeepdriver1980 jeepdriver1980 is offline
Exclamation Jeep won't start with the key
Well im at a standstill not knowing what to do about my jeep, you can put the key in turn everything on but the starter wont turn over, but you can use the old screw driver on the starter trick and it starts right up, so does anybody have any ideas on what this might be ive replaced the starter relay and battery cables what else could it be? any advice would help from anyone
Old 08-20-2005, 01:55 PM
Saudade's Avatar
Saudade Saudade is offline
Re: Jeep won't start with the key
In the Start position, you should get battery voltage at the starter relay.
Your handle implies a 1980 jeep but your profile says 1988. An 88 with an automatic trans has a neutral safety switch that prevents starting in gear. If manual, there's a switch on the clutch pedal that essentially does the same.
If auto, try wiggling the shifter around. Also put it into neutral and try.
Old 08-20-2005, 07:33 PM
89ltd 89ltd is offline
it could be your ignition switch as well, not sending the signal to the starter relay.
Old 08-21-2005, 12:40 PM
bayouwolf's Avatar
bayouwolf bayouwolf is offline
Re: Re: Jeep won't start with the key
Have you checked for voltage at the starter relay with the key in the start position?
It's all fun and games till' someone gets banned. Then its fricken hilarious!
Old 12-22-2005, 11:29 AM
jjdavis jjdavis is offline
I have the same problem, can you tell me if you fixed yours and how?
