Door Panel
Hello, How to dismount the rear panel on PA 93 for check windows motor? I saw on the www how to dismount radio. we have to pay with Paypal .
GM only |
Re: Door Panel
Remove all screws you will find (door handle, the one behind the opener etc., then remove the panel with the switches - just carefully pull it out, then pry off carefully the panel. It is best to start at the lower back corner, then with your fingers and without pulling too straight you have to draw the panel pins off their locks. When it is hanging only on the upper side (do not forget the upper plastic pins) then pull upwards to get it from the retaining lip at the inner window inlet.
But maybe it is sufficient to pull out the switch and test that.
For road: Buick Park Avenue 1992 3.8l For off-road: Jeep Cherokee Laredo 1988 4.0l For fun: Chrysler Imperial Crown 1963 (413 cui, 340 hp) |
