Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 08-20-2005, 09:28 AM
xrs4tess xrs4tess is offline
corolla xrs fuel grade
What grade of fuel are you using in your XRS.Had any problems with regular 87 ?
Old 09-03-2005, 11:35 AM
kevibobo kevibobo is offline
Send a message via AIM to kevibobo
Re: corolla xrs fuel grade
91 should be used because of higher compression ratio. You shouldn't use 87, it might sludge your engine in the long run.
Old 09-04-2005, 03:59 PM
andr3w andr3w is offline
are you serious? i'm not going to buy one if I can't put cheap gas in it
Old 09-04-2005, 06:42 PM
93rollaracer's Avatar
93rollaracer 93rollaracer is offline
Send a message via AIM to 93rollaracer
It should be fine on 87. Just ask the dealer when you go to look at it.
Proud member of DAMM: Drunks Against Mad Mothers
Originally Posted by vinnym86
Metalheads: 93rolleracer
crazy sons of bitches who get hammered, break shit, and scream. yeah, they're pretty cool. right up to the point when they lynch a black guy.
Old 09-06-2005, 10:31 PM
Compression ratio is a bit higher on the Xrs 11.5 vs 10 on LE 91 should be used to prevent premature ignition at the plugs in the engine
