Old 08-20-2005, 09:05 AM
nfoy413 nfoy413 is offline
Unhappy 1997 GMC Jimmy Front-end SQUEAKING
I recently purchased this 97 Jimmy SLT 4X4 and have found that the front-end is producing this aweful squeaking noise. It doesn't seem to be the shocks/struts. It only happens when the vehicle rocks side-to-side. A friend of mine said to lubricate the "a-frame", which I sprayed lubricant on with no luck. Does anyone have any suggestions on where to start chasing this SQUEAK down!!? It's driving me crazy! :-)
Old 08-20-2005, 06:10 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 1997 GMC Jimmy Front-end SQUEAKING
Grease your front end.
http://www.automotiveforums.com/vbul...d.php?t=344505
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 08-21-2005, 07:56 AM
Bads Crew's Avatar
Bads Crew Bads Crew is offline
I think your friend is correct. I have a 95 Blazer that does the same thing. Its the bushings in the upper swing arm. I have to soak em down with WD to make it stop. The shop I go to hates to do the job because it a P.I.T.A. The rubber bushings need to be replaced because they are hard due to age.
Old 08-21-2005, 09:06 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Heh. I just replaced my upper control arm bushings yesterday... Fun fun....Though my damn knock/jump while turning is gone...LOL... Though at least I got to play with the oxy/acect torch...LOL.. Though squeaking can come from several places up front
Body bushings
Control arm bushings (check for dryrot/cracks on the rubber edges)
Ball Joints (lack of grease, if that's happened, it's shot and needs
replaced)
Tie rod ends (same as ball joints)
swaybar links and bushings...(again, dryrot/cracks)
Old 08-21-2005, 11:14 AM
Bads Crew's Avatar
Could be a simple as the hood hinge or door hinge.
Old 08-21-2005, 11:38 AM
BlazerLT's Avatar
AF -Advisor
Could be as simple and go getting a grease gun.
