Rust
ok i have little rust in the back of my car buy the fuel tank on the chassie, and a little buy the struts in the engine bay, is there any way to get rid of it, ive seen that stuff at ace that stops rust does that stuff work or no. thanks alot.
Re: Rust
You need to grind it out, then treat the bare metal. When it comes to rust, I do not try to put a band on it, because it will continue to eat your car.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper. |
Re: Rust
Rust is like cancer, the only way to get rid of it or stop it is to remove it.
Check out more pics and info on my Stang at: http://www.cardomain.com/profile/2crunk ![]() ![]() Rest In Peace Hypsi87, you'll be missed. |
Re: Rust
You need to clean it off, using a dremil and a soft sander, and then go buy this product POR - 15 http://www.por15.com/ which is what I use to paint any bare metal. I use the HARDNOSE version of their paint with the Grey color since I have a silver mustang. The paint is awesum, you can beat on it with a hammer, and it won't chip. We used this in the military, and it's the ONLY paint that is better than powercoating. Basically when it comes to protecting your metal.. you have three choices... Powder coating, Line-X / Rhinolining and POR 15........ and this POR 15 is actually the ONLY paint that will STOP rust. You can can actually paint over rusted stuff with it, and it will stop rust from getting worse.
My ride at my site Silverstangs. |
Re: Rust
so i clean the rust pritty much take some of it off with sand paper and then paint over it with this stuff.
Re: Re: Rust
That's correct. Home depo sells a sponge type sanding block, that's what I used. I also use the foam style sanding disc with my dremmil in the tight areas.
Re: Rust
thanks alot.
