Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 08-19-2005, 10:22 PM
exploreco97 exploreco97 is offline
Question Oil Change mess
I have a 97 Explorer XLT 4.0 SOHC. I change my own oil and as you know, when you let the plug go, the oil goes all over the frame and gets everywhere.
Does anyone have any suggestions to drain the oil into the pan without getting it everywhere? I have tried the fram sure drain but don't like it.
Old 08-20-2005, 12:18 PM
mikephotos mikephotos is offline
Re: Oil Change mess
The Fumoto Value is the only way to go.
http://www.rampslides.com/explorer/oilchange.html
Just to add. Read thru this post (it's long but very good info) and you might be able to find a discount code that still works. Even if you don't the $$ you pay is well worth it. Get the one with the nipple, it comes in handy.
http://www.explorerforum.com/forums/...ad.php?t=68624
and the Fumoto site:
http://www.fumotovalve.com/
This is not a cheap piece like the Fram. You'll be very pleased, I know I was (and still am every 3,000)
Mike
Old 08-28-2005, 11:23 PM
asemstr asemstr is offline
Re: Oil Change mess
A trick I learned at the dealership! Flatten the oil filter box and use it to redirect the stream into the pan!
IS IT FIXXED YET?!
Old 10-01-2005, 10:08 PM
fixmyexplorer fixmyexplorer is offline
I have been changing oil in my 97 (bought new) with same engine as yours. I am able to do it without jacking up the SUV. I use a wide mouth drain pan and also have a 4' x 6' galv flat drip pan that I have had for years just in case. I don't have the problem that you are having with the drain pan.
However, when the filter is removed, thats where the running over the frame occurs for me. Any suggestions with the oil filter?
By the way, it just tripped 203,000 miles and is still going strong using Castrol from the beginning.
