Old 08-19-2005, 09:58 PM
Whizbanger Whizbanger is offline
4sp 2 5sp transmission
89 civc hatchback, 1.5 liter, 4 speed trans. Hey there, I've obtained a 5 speed transmission from a 90 crx. There's no marking that I can find, unless I don't know where to find them. 2 questions, 1) will the transmission, clutch(when buy new kit) and cv joint all bolt up to my current ride? 2) How do I find out if the 5 speed transmission is any good short of tearing it down?
Thank you, Joe
Old 08-19-2005, 11:38 PM
maxassassin's Avatar
maxassassin maxassassin is offline
Send a message via AIM to maxassassin Send a message via MSN to maxassassin
Re: 4sp 2 5sp transmission
ok question one. al ld series trans missions should bolt up to d seires block. question to theres to ways to go aobut this. one yo ucant slap it in and pray or 2 yo ucna not drag aroudn the bush and jsut do the rebuild.
06 cbr 600 f4i
91 civic hatchback.
96 nissan pathfinder
Old 08-20-2005, 12:26 AM
I only know 2 languages, 1 is American Sign Language (I'm Deaf) and 2nd is English. What was said above post, look like pig latin mix with greek to me. Unless I have Pink Floyd music blasting in background while suckin on a bong that's as big as lamp, there's no way I can make out on what was just said. Joe
Old 08-20-2005, 12:33 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
I think he's forien, he allways types like that. Translation:
"Ok, question one. All “D” series transmissions should bolt up to “D” series blocks. Question two. There’s two ways to go about this – one: you can slap it in and pry, or two- you can not drag around the bush and just do the rebuild."
By the way, I think you have to change the shift linkage to make it work, not possative though.
Old 08-20-2005, 11:58 AM
Hybrid1990crx's Avatar
shift linkage will be fine. what model is your car, if its a STD then you will have to change the hubs. The clutch and flywheel should work fine, unless you want to freshen it up a bit and put new stuff in.
Old 08-20-2005, 05:58 PM
Kunundrum's Avatar
Kunundrum Kunundrum is offline
Send a message via ICQ to Kunundrum Send a message via MSN to Kunundrum
you don't need to change the axels, the 4 speed ones will work fine. all you Need is the tranny, if you use the 5 speed axels you need to change you hubs to dx, Si ones like mentioned above.
2012 VW Golf 3 Door Automatic (Company Car)
2011 VW Golf Wagon 5 speed (Company Car)
2010 VW Jetta 2.5 Automatic (Company Car)
2009 VW City Jetta 5 Speed (Company Car)
2009 VW GLI 6 Speed (Company Car)
2008 VW Jetta 2.0T 6speed (Company Car)
1999.5 Audi A4 Quattro Sport 1.8t (Chipped 1.0 bar) Sold
1990 CRX Si (Built B17a) - Stripped and Crushed
1988 CRX Si -- Stolen
1990 Civic Cx -- Sold
1990 Civic Si -- Parted
1989 Civic dx -- Sold
Old 08-20-2005, 08:16 PM
I got online to look up the pricing on clutch kit for my car. When I decided to reference check between the two car... I find that the 89 honda hatchback use 7 7/8 clutch with 4 speed, and a 90 crx use 8 inch clutch with 5 speed. I am not sure, it's my daily driver, I have to know if everything will work before I do anything. Thanks Joe
Old 08-20-2005, 09:52 PM
ok first off im not forgien by any means unless you wanan talk hertiage. but silent chamber understood what i was talkin about. mostly.
06 cbr 600 f4i
91 civic hatchback.
Old 08-20-2005, 10:13 PM
forcefanad forcefanad is offline
Thank you, Joe
ok...you have a standard model civic hatchback....you need hubs axels the tranny and a clutch kit....you can use either si or dx hubs...but my reccomendation would bo to get ex hubs "4 door civic" because the brakes are slightly bigger...if you try to use the standard model hubs and axels it WILL not work...the splines on the inside are different...standard models have 23 splines and i believe the si's ex's dx's and hf's all have 28 splines....dont quote me on that tho.
hope this helps
adam
Old 08-21-2005, 12:47 AM
dfarres's Avatar
dfarres dfarres is offline
Send a message via Yahoo to dfarres
The splines on the tranny side are the same for all models, it's the hub side that is different for the STD model. I know because I had a 4spd tranny from a STD in my DX and i replace the axles with DX ones and it went in fine. Use the axles from your car and the clutch that goes with the tranny.
1993 Civic Coupe EX
1997 Chevy Suburban LT
“It's all fun and games - Until someone loses an eye"
Old 10-26-2014, 09:25 AM
lowet lowet is offline
Here is another question i have an 88 std and want to do the switch from 4 speed to 5. Well i heard in 88 there is more to b done than usual
