map or maf sensor cause a no start?
i was looking over old threads and retrying some suggested things and tried what iroc said about the two pins in dlc and finally got it right and got the code 33 which could either be maf or map according to the book i have. could either of these cause a no start?
Nitrous= the car equivalent of a penis pump |
Re: map or maf sensor cause a no start?
What year, type of motor/injection system?
89 camaro tpi 305
Re: Re: map or maf sensor cause a no start?
not likely. I was driving mine without the maf since it was burnt,but it was a 6 then. I believe the perfomance would be affected. It would run leaner relying on O2 sensor only.
If thats a no start check for loose connections,the battery(sometimes the engine will crank but the plugs wont fire), your ignition module,presence of fuel pressure. +Sometimes a bad fuel pump relay or oil pressure switch will create this problem or exessive cranking time Any engine will run if theres gas and a spark. |
To my knowledge the ecm in his car does not cut spark due to low oil pressure. Being that there is a code 33, something is wrong with the MAF circuit which you will need to fix whether it runs or not. It better to do what Morley has suggested and replace the relays, than spend $100 on a new MAF and find out it's just a bad relay. |
it does thats why a bad relay can cause long starting periodes, The engine wont fire untill certain oil pressure is reached.And thats in combination of things can lead to no start.
Also if the spark is weak it may fire a bit too.Furtermore, incorect timing can be an issue only if you messed with it, right? Anyway a bit more info would be helpful. |
what info would u guys like
Well did you do any work to it lately?
nothing really never have the time i work 6 days a week minimum of 12hours a day. the car really needs some love but i believe you put your heart into a car it will come through for you when its time to race or help u pick up some panties along the way
I'd still replace those relays.
Does the engine crank? Have you checked for spark/fuel pressure? |
refer to morley's post please
Chevrolet Camaro - I enjoy beating the hell out of people http://www.automotiveforums.com/vbulletin/showthread.php?t=68052 |
stupid noobie question but burn off relays? also would a junkyard maf sensor work?
http://cgi.ebay.com/ebaymotors/82-92...QQcmdZViewItem
this one work on rs? also great to see u stayed 89 i would be lost without u
