Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 08-19-2005, 04:29 PM
BULLITTR6 BULLITTR6 is offline
Send a message via Yahoo to BULLITTR6
Stuck in winter mode
My '93 Rodeo seems to be stuck in Winter mode as it takes off in 3rd gear all the time now. Can't select or de-select the mode with the switch and have no indicator light on dash. Also, the "check trans" light flashes rapidly all the time. Haynes manual is no help and the stealership of coarse wants me to bring it in. It was intermittent at first but is constant now. Does anybody know what might be wrong or how to diagnose it? Thanks.
1991 F350 dually w/ 7.3 deezal
2008 Mustang GT
1993 Rodeo LS w/ 3.2 v6, 2wd (daughters)(Now totalled)
1991 Yamaha XT600
1993 Honda CR250R
Hard tellin', not knowin'
Old 08-19-2005, 04:36 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Stuck in winter mode
Pop the switch out and unplug it.
then report back.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 08-19-2005, 05:05 PM
Thanks 2k, I did that a couple of days ago. Went so far as to take the switches apart to check contacts, but were good. (A word of warning: if you take the winter or power switches apart, BE CAREFUL! There are 2 small ball bearings on springs that roll on the contacts that will dissappear on you! You have been warned! )
I did a search, should have done that first i guess, and got some helpful suggestions that I will try. Where is the range selector physically located?
Will post updates.
2008 Mustang GT
1991 Yamaha XT600
1993 Honda CR250R
Old 08-19-2005, 09:33 PM
Isuzu Guy
I don't know if you have a range sensor on your 93?
How is the fluid level?
-Ryan
Isuzu Moderator
Car Show Tips
Old 08-19-2005, 11:16 PM
The level is good. It was just a tad low originally, so I added some Lucas Tranny oil stabalizer. This was an attemp as a fix also. The oil is still slightly red but showing some age. Not burnt though.
2008 Mustang GT
1991 Yamaha XT600
1993 Honda CR250R
Old 08-20-2005, 10:10 AM
rodeo02 rodeo02 is offline
The transmission range / mode sensor on your 4L30E is bolted to the shift arm that sticks out the driver's side of the trans case. It's a credit card sized 'black box' with a wire harness plugged into it. If the wiper arm and circuit board in the sensor dont make a good electrical contact, you can get the conditions you have. I would look into the TRS. As far as I know, all 4L30E's have them.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 08-21-2005, 02:02 AM
Thanks Rodeo02, I'll look into that more closely tommorrow in the day light. Crawled under it tonight to look for something obvious and found one broken wire and two chaffed wires in the tranny bundle right where it lays across the engine oil pan. Spliced the wires and wrapped in new conduit. I was really excited but as it turned out, all I fixed was the speedometer problem. Not that I'm complaining, I just thought I had a hard fix on the tranny. I'll keep plowing on. Thanks for the help guys.
2008 Mustang GT
1991 Yamaha XT600
1993 Honda CR250R
Old 08-21-2005, 10:25 AM
Yep. Check all the wiring you can find around the trans case & exhaust. The 1993-1997 rodeos are notorious for getting burnt or chaffed wiring around the trans, even right thru the wire looms .
G/luck
Joel
Old 08-22-2005, 01:04 AM
Well pulled the range/mode sensor apart today. Contacts looked clean as did the circuit board. Reassembled and reinstalled with no joy yet.
The Haynes manual called it the neutral safety switch but I'm sure it does a host of other functions as well.
I've looked at all wires and sensors to the best of my ability but haven't had any luck yet. I need to find out what a code 34 on the tranny controller is. That's what's flashing.
2008 Mustang GT
1991 Yamaha XT600
1993 Honda CR250R
Old 08-22-2005, 07:16 PM
matemk matemk is offline
Send a message via AIM to matemk
ive had the same problem, starting out in 3rd grear/winter mode crap, check your wiring harness going to the 3 sensors on the tranny, follow it up to the connector and pull it all out, try re-wiring all of the wires and see what that does, i did it to mine and it worked, it got me out of "limp mode"
Old 08-26-2005, 12:17 AM
Man, this is driving me crazy! I had the alternator checked, was all ok. Finally found out what the "check trans" code 34 is from a transmission shop. It's for the MAP sensor. So I buy and install one, but it is no help. I can, however, now select and de-select the Winter Mode and the dash light appears, It just never starts off in first gear like it should normally. I'm running out of ideas. Anyone? Anything?
2008 Mustang GT
1991 Yamaha XT600
1993 Honda CR250R
