Old 08-19-2005, 03:02 PM
AFI 05 AFI 05 is offline
Send a message via AIM to AFI 05
Angry fans dead
alright.. it takes a while for my car's temperature to rise, even longer if i go on the freeway, it stays below the midpoint so i know my cooling system isnt at fault. But yeah my fans dont turn on at all.. not the primary one nor the second one. Not even when i turn on the AC.. i did that to test it cause the fans are suppose to turn on when the AC is on (correct me if im wrong) so yeah.. what could be the problem? fan motor dead? wiring? fuses? what are other possibilities..hopefully it isnt something too severe.
Old 08-19-2005, 03:04 PM
Re: fans dead
yeah and i opened the hood with the engine running while the temperature was above 220 and the fans were still off.
Old 08-19-2005, 04:19 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: fans dead
Erg, feel your pain these sytems are so simple yet so buried and frustrating.
How hot has the motor gotten? (do you know when your fans normally come on, s/b around 230*)
The secondary (right side) should come on with the a/c, it may take a a minute or so, manifold pressure has to build to close the switch and activate that fan.
The primary is controlled off a switch in the right cylinder head between cyl 6 & 8. You could pull the wire (green I think) off the switch and ground it to see if the fan runs.
Atleast that will get you started.
Old 08-19-2005, 05:52 PM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
If it does run by doing the green wire thing, then you gotta replace the thermostat, I would check your owner's manual, find out what fuses are your cars fan motor fuses and check if they're blown.
Old 08-20-2005, 07:27 PM
supervisor1886's Avatar
supervisor1886 supervisor1886 is offline
Banned
Re: fans dead
Wire the fan to the battery and ground and see if it works.Then instal a manual switch with a relay to activate it manually.Its fun too. Fuck all those fan relays and temp switches.(one of them is your problem or a bad ground may be)
I run my car at minimum operating temp all the time with the switch.Your engine will thank you when in a traffic jam.
Old 08-21-2005, 09:34 PM
philly rs's Avatar
philly rs philly rs is offline
Send a message via Yahoo to philly rs
Re: fans dead
i feel u man, my fan died on me 2 weeks ago, 70 bucks to get a new motor. if the right fan is out the second one wont run at all, it runs off the first fan so that sucks ass.
Your import sounds like my ass after a night of mexican food..
And spraying aint cheating, its brining a gun to a knife fight!!
yeah, its a v6 RS...never mind the f1 badges lol
HYPSI87 u will be missed
Old 08-22-2005, 12:07 AM
Banned
Re: fans dead
junk yard fans are cool ($20)
Old 08-23-2005, 01:54 PM
Re: fans dead
alright i gave the fans some power and they worked so it wasnt the fan motor.. we checked the fuse and it was fine but i put in a new one just in case for some reason and it worked.. i dont know how but now it works.. hooray.
Old 08-23-2005, 10:30 PM
Banned
Re: fans dead
Wire shit or the relay got free, or the CTS suddenly worked. If its not the wires it will happen again.
