Old 08-19-2005, 02:57 PM
JRTFRED's Avatar
JRTFRED JRTFRED is offline
Front end vibration with light braking
My 98 Blazer gets a vibration in the front when applying the brakes lightly. If the brakes are applied harder, the vibration goes away. I replaced the rotors and pads (Bosch rotors and metalic pads) thinking it was a brake issue which seemed to diminish the vibration, but not delete it. Any thoughts?
Old 08-19-2005, 04:02 PM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Honestly it sounds like warped rotors. I had the same thing happen 12k into a new set of rotors and pads. Good luck
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 08-19-2005, 04:24 PM
JRTFRED's Avatar
Re: Front end vibration with light braking
It was still there with the brand new rotors.
Old 08-23-2005, 10:21 PM
Kordog Kordog is offline
Did you check your rear rotors? Since you start off braking lightly the rear brakes are working almost as hard as the front brakes but as you brake harder the rears work less. The rear brakes only do about 30% of the braking under moderate to hard braking so your pulsation could go away with harder braking.
Old 08-24-2005, 08:12 AM
JRTFRED's Avatar
Good thought ! The rears have a few more miles than the fronts had, but I didn't think of changing them. Thanks, I'll try it.
Old 08-24-2005, 08:20 AM
Does sound like warped rotors. But could it be ball joints? Maybe tires need balancing? Check the brake fluid level?
K&N Air Filter
