Go Back   Automotive Forums Car Chat > Plymouth > Breeze
Old 08-19-2005, 02:54 PM
Breezer2.4 Breezer2.4 is offline
Question srange engine noise
i have a 1999 blymouth breeze 2.4L, at around 1700 rpms the engine makes a noise that almosts sounds like a grinding noise, but it only makes this noise at that rpm. any ideas about what it could be?
Old 03-07-2006, 03:51 AM
mcrosby mcrosby is offline
Re: srange engine noise
Bad motor mount? Need more info.
Old 03-10-2006, 10:20 PM
mechanical_zero mechanical_zero is offline
Listen to the motor if you can to try and determine where the sound is comming from. My guess at this tim eis the water pump may have failing bearings. The fins in the pump then scrape against the engine block making a squeal/grinding sound.
