Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 08-19-2005, 01:44 PM
Ledebuhr1 Ledebuhr1 is offline
getting paint to re-paint a GM??
I need to repaint the rear passenger side quarter panel on our GM. The clearcoat went bad on that piece. I got two differnt spray cans that were custom mixed for the color of the GM. Both were off, the last one I used to paint it is just a little too dark.
I have someone who will paint it, but he wont unless I can get the paint. He says it is hard to match so it will look right.
Anyone have a idea where I can get a small container of Opal Frost paint for a 94 GM?
Old 08-19-2005, 07:03 PM
reekor reekor is offline
Re: getting paint to re-paint a GM??
Any automotive paint store will be able to mix it for you, you’ll need the paint code from the front drivers door tag. No matter what, you wont get a perfect color match since the rest of the car has 12 years of paint fade.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 08-19-2005, 08:19 PM
Thanks, I called the local paint store and they will make a pint for $42.
If they cant get it exact then how do body shops match paint when someon gets into an accident?
Old 08-20-2005, 07:45 PM
Re: Re: getting paint to re-paint a GM??
If the car is only a few years old then it no big deal since the paint isn't overly faded. But we're talking about a 12 year old paint job here. I have a 94 CV that I have repainted a fender, header and bumper cover on since the rest of the car's paint was almost mint. What I did was painted the car and about a month later wet sanded the newly painted parts and buffed out the clear coat to match the rest of the car, This gave the new paint a bit of a aged look, but still on a sunny day when the car is in direct sunlight you can tell that it's a bit off. I'm guessing that it's a metallic paint that you have on the car, you can lighten it up a little with a very small amount of silver mixed into the paint but like I said before you'll never match the old paint 100%.
Old 08-20-2005, 11:22 PM
cobradude360's Avatar
cobradude360 cobradude360 is offline
Send a message via AIM to cobradude360
i had the same problem but with my hood and the hole paint job was looking pretty bad on my 94 from scratchs and just fadeing so i had my buddys uncle who owns a maaco at 12 and grosbech if u know were that is paint the whole car and dang does it look sharp and it was only $630 so th choice is urs good luck with the matching
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that
MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs
also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon
