2000 Blazer 4WD causes wheel lockup on tight turns
Greetings:
First, I love this forum and others like it where everyone helps out. I was in a parking lot yesterday and turning my wheel hard left when my Blazer acted as if the brakes were on. When I straightened the wheels out it was OK. I turned them hard right and the same thing happened, acted as if I was stepping on the brakes (which I obviously wasn't). I checked the power steering fluid and it was OK. Then I noticed I was in 4 wheel Hi but I usually have it in 2 wheel hi and had not changed it to 4 wheel. My wife says she did not and the kids say they did not. Maybe I bumped it by mistake.But, when in 4 wheel hi is this a common problem? Once I put it in 2 wheel drive everything was OK. Thanks |
Re: 2000 Blazer 4WD causes wheel lockup on tight turns
you are not supposed to go full lock on the steering with the 4wd engaged.
1995 Factory Blazer Service Manual for sale, PM if interested. |
This is not a problem at all. When you engage your 4WD, of course there is a certain amount of resistance while you are turning all the way because all the tires are driving and they will fight each other a little bit. What WILL cause a problem is having 4x4 engaged without even knowing. Your not suppose to run you 4x4 on dry pavement at all, I dont even run mine on wet pavement (not that i would ever need to), because that will severely shorten the life of all your parts related the 4x4 system.
Thanks for the good/bad news. Good that it's not a problem for what I described and bad that I don't know how long I was running on 4WD and why. I'll have to glance at it more often or maybe I'll recognize how it's driving and know it's in 4WD. I just got my Blazer a month ago and I'm still learning about it.
Thanks!! |
