Old 08-19-2005, 10:36 AM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
Going to install h2o injection today :)
I think I really have only just one question and that is where is the best place to wire from my ignition switch? Or something to the rightside of the car that will allow me to turn on/off the injection while the car is running.
I will be installing a switch and a few other things also, can I wire everything from the same wire? Or is it best to do it in different spots...I planned on just using 3M clips and running 1 wire from my power source, then all the other things off the wire( figure thats the easy way).
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 08-19-2005, 11:20 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Why do people use alcohol/water injections? I've read about it before, I just dont know why its done.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 08-19-2005, 12:33 PM
tr10av tr10av is offline
Send a message via MSN to tr10av
Re: Going to install h2o injection today :)
It helps cool the intake temperature down. When the turbo compresses air it causes the intake air temp to rise. This causes the air to thin and leads to engine knocking.
http://www.rallycars.com/Cars/WaterInjection.html
Old 08-19-2005, 12:37 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
learn something new everyday...
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 08-19-2005, 08:00 PM
Turns out I had to redo my fuel pump AGAIN >....I can possibly mount the box in my car tomorrow early in the morning then maybe if I have sunday off, rewire, if not, itll be like a week or so until i can
95 Eclipse GS-T
Currently:
Soon lol
Old 08-19-2005, 08:22 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Awesome, did you get a kit or did you buy the stuff seperately? I'm planning on making my own kit cause you can do it for like a third of the cost, are you going to run straight water or a water/alcohol mixture? When i make my kit i'm gonna get a pressure switch so it will turn on at like 18psi.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 08-19-2005, 08:45 PM
kjewer1 kjewer1 is offline
AF - Advisor
The charge temp reduction is only a very minor part of the benefit of water/alcohol/methanol injecton. The real benefit is from what happens in the combustion chamber. Water has around 7 times the latent heat capacity of fuel. In other words, it will absorb 7 times more heat energy in the conversion from a mist to a gas/vapor. Thats where the real temp reduction is done It also acts as somewhat of a buffer supressing out of control burn rates.
There is a guy on the DSMlink forums that posted up a log of his car running exactly the same airflow and settings as my car when it went 11.3 at 126, except he's on 91 octane He runs a mixture of 75% methanol to 25% water, injected at rate of 20% of fuel flow (system taps into the injectors to determine this ratio) rather than just off/on. Pretty slick setup. And moving 65 lbs/min all day on the street is sure to be a good time.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 08-19-2005, 08:53 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
^^^Genious^^^
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 08-20-2005, 12:45 AM
Thor06's Avatar
Jizzed In My Pants
Originally Posted by l_eclipse_l
^^^Genious^^^
I agree, thanks for the input guys.
Old 08-20-2005, 02:31 AM
Yea I just bought the kit, I have a really nice box Im gonna install in my trunk that fits to the sides of the trunk almost perfect, but my damn FP decided to basically come apart where i connected it, so it took like an hr or so for diagnostics, trips to the autoparts store, figuring out which way my plugs were supposed to go and then finally finishing around 7:30....I hope I have sunday off, I might just say I have plans and I cant work
95 Eclipse GS-T
Currently:
Soon lol
