Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 08-19-2005, 10:14 AM
futebol09 futebol09 is offline
Angry 99 V6 engine shot
I have a 99 rodeo, need I say more. Anyway, I bought it used and soon after it started dying at stops, going down the freeway, etc. I've read the posts and it all sounds like same problem. Well, off to work one morning and it dies on me. Started loosing power and pulled off the road and it dies. I have a couple of mechanic friends and they tell me the #1 piston rod is stretched. It blows oil out the dipstick. Vaccuum runs backward. Timing belt was still good. Didn't appear to jump time.
Any help? I'm looking for a new engine.
It only had 67,000 miles on it. Changed oil 500 miles ago.
Old 08-19-2005, 10:17 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: 99 V6 engine shot
How much oil has it been using?
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 08-19-2005, 10:41 AM
It hasn't been using a lot of oil. I was just driving to work about 65mph when it just lost power.
We thought it might have jumped time, When we got to the belt it was were it should be. I bought a new one just in case, but we couldn't turn the engine. It's locked up. Still full of oil.
Old 08-19-2005, 01:00 PM
rodeo02 rodeo02 is offline
I've never heard of a stetched connection rod, especially on the 3.2L. If that was the case, That piston would have smashed against the valves. If your engine is not knocking and you are not loosing oil press (bad bearing), the engine is probably fine. You will have to do a compression test to see if the valve timing is correct or not.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
