Old 08-19-2005, 08:39 AM
legolazzz04 legolazzz04 is offline
Whats going on!!!
My 1991 Civic HB DX has been running pretty good with no problems. One day I start the car and I'm driving the car and the battery light turns on. I get worried because I'm on the highway. Anyways I went home and tested the battery and it was fine. I even took it to test the battery at the store. It was fine as well. So the guy said it could be the alternator but that wouldn't make sense because the car starts with no problem every time I turn it on. That light keeps coming on now and I have no clue WHY!!!! What do you think??? Could it be a short circuit or some kind of relay? Please help. Thanks in advance.
Old 08-19-2005, 09:21 AM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
It's probably the alternator.
Old 08-19-2005, 10:08 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: Whats going on!!!
I agree. Your car may start fine now but if you listen to your stereo and use your A/C or headlights then try to start your car later it may not happen. Have your alternator tested and check your grounds.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 08-19-2005, 10:28 AM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
light came on b/c it's a warning light...don't want it to come on when your car breaks down...but light they said above...get the alternator tested
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 08-19-2005, 01:49 PM
skotman's Avatar
skotman skotman is offline
your alternator could be putting out too much voltage. i dunno if the car's sensor is that intelligent or not, but i've had a voltage regulator go out on my old nissan pickup, and it began to slowly fry the battery. i smelled the burning battery for weeks before i finally noticed headlights getting super bright the faster i drove. changed it as soon as i found out. battery didn't last much longer than that either due to being fried.
