Old 08-19-2005, 06:28 AM
Phreak's Avatar
Phreak Phreak is offline
Send a message via ICQ to Phreak
Tamiya PS Spray Paints?
I still have a can of Tamiya PS-16 (for polycarbonate) laying around that would suit the WRX STi that I'm currently building well. Does this type of spray interfere/react with the Tamiya primer and the Tamiya TS-13 clear or can I just use it like any other TS spray paint?
Couldn't find this anywhere on the forum, as PS is under the minimum word length
Thanks!
Finished:
In progress: Tamiya Subaru Impreza WRX STi (Mica Blue), Italeri Porsche 911 Turbo 1995 (Black).
In stock: Tamiya Nissan 350Z "Track" (Chrome Yellow).
Old 08-19-2005, 07:06 AM
SteveK2003 SteveK2003 is offline
Send a message via AIM to SteveK2003 Send a message via Yahoo to SteveK2003
Re: Tamiya PS Spray Paints?
PS is polycarbonate spray paint. It doesn't react well with plastic, if it sticks at all, and will dry to at best a semigloss finish. It is specially formulated to stick to flexible Lexan.
Your best bet is to use 'real' model paint, and not take a chance on that stuff.
Old 08-19-2005, 09:31 AM
MikeWz MikeWz is offline
Send a message via AIM to MikeWz
You're lucky if you get even a semi-gloss out of it. It is meant to be used on the inside of the polycarb bodies so it can use the plastic to make it look glossy
Current Model: Ferrari F50
Old 08-28-2005, 06:12 AM
Phreak's Avatar
What if I primer the body, then spray the PS and finally some TS13 clearcoats? Will it shine then or will it still be dull?
Finished:
Old 08-28-2005, 06:58 AM
mickbench's Avatar
mickbench mickbench is offline
I really would just go and buy some plastic model spray as I'm not sure of the PS spray will react well with the TS Clear.
Perhaps someone has done this before but I think it could craze..
Old 08-28-2005, 11:44 AM
blubaja's Avatar
blubaja blubaja is offline
I sprayed the PS colorshifts on the metal rsx kit I have. It stuck ok but the finish came out flat. I tired a few clears, but they went flat too...so..I dunno. Try a test piece 1st. Find a right clear.
Frank X.
Old 08-28-2005, 05:29 PM
Phreak's Avatar
Alright, I'll try a piece then. Maybe it'll work out
Finished:
