Old 08-19-2005, 03:57 AM
talon96 talon96 is offline
Send a message via AIM to talon96 Send a message via MSN to talon96
Exclamation wont stay runnin...help!?
:disappoin I dont get it...My 96 Talon will stay running half of the time...and then die after a min. or right away. when It stays runnin it idles at 1 rpm. I just re did the whole motor and dont understand. could it be vaccum, fuel. what, all the spark plugs are new and firing, theres oil, antifreeze, all the fuses are good, the fuel injectors are getting fuel to its destination, the only thing that helped it stay runnin half the time was unpluging the egr valve...please help Ive never dealt with a dsm before and this car hasnt run since I bought it...
thanks,
Talon96 :confused:
Old 08-19-2005, 02:20 PM
Re: wont stay runnin...help!?
Why can no one help me?!? :-(
Old 08-19-2005, 02:55 PM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
Hate to say it man, but i was told you have to run tests according to the book/ repair manual and post them that way they can help ya
Old 08-19-2005, 03:28 PM
Thats okay, I figured it out anyway...
Old 08-19-2005, 04:45 PM
LouieAWDTSi's Avatar
LouieAWDTSi LouieAWDTSi is offline
Re: Re: wont stay runnin...help!?
What was the solution?
--the Cruiser-->97 Spyder GST 5sp ---3 inch exhaust, boost/vac gauge, mbc, greddy turbo timer, greddy fmic, greddy type S BOV, 17in wheels
--the DD-->99 ACURA 3.2 TL
--Sold 92TSi AWD, 6-bolt, auto, evo 3 gt turbo with supporting mods
Old 08-20-2005, 11:32 AM
well first of all the solution brought another problem so... when it didnt stay running while the engine was go, but turned over fine and ran when I completely dissconnected the egr seloniod, turns out I looked inside the egr s. where the computer plugs in and there was only one prong where there shouldve been two, not to mention when I took it off and shook it, there was no ball inside the seloniod, solution, I got a another seloniod and plug from a friend who owns a junk yard. spliced the plug wires hooked it up and wella, problem solved, or so I thought. It ran for about twenty minutes till it got just above warm and poof, she shut down, and there was nothin I could do to restart it, couldnt keep it runnin with gas so I figured, sensor, so I borrowed an ohm tester from my dad and the first thing I tested was the culprit, the front oxygen sensor. got another one of those and she runs like a beauty. :-)
Old 08-20-2005, 11:33 AM
just a note I was typing in a hurry and I meant while the engine was cold, not go. lol
Old 08-20-2005, 05:11 PM
Very good job. Thanks for posting back.
Old 08-20-2005, 08:31 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Good to hear it all worked out. Good luck with the car.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
