Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 08-19-2005, 01:23 AM
NiSmO_zt's Avatar
NiSmO_zt NiSmO_zt is offline
Send a message via AIM to NiSmO_zt
put coilovers on --> have quiet roar in rear end ???
so ive got my mr coilovers on today, adjusting them and such like 10 times to try to get the noise out of the rear end. its not too bad of sounding noise, but i cant pinpoint the problem. the car is lower than it was, but its way higher than monoxides car in the rear, i have about 1" between the top of tire and the fender, and in the front its about .5". it kind of sounds like scalloped tires you know "wong wong wong" increasing with speed, but it wasnt there before, and the camber is not very bad.
more air in the tires? keep raising the back up until the noise stops?
how do others go so low without problems?
im blue in teh face from taking my wheels off and adjusting my co's
everything is tight, no marks on tires, or half shafts from rubbing
thanx
peace
my current 240--ka-t
Old 08-19-2005, 12:17 PM
NiSmO_zt's Avatar
Re: put coilovers on --> have quiet roar in rear end ???
put more air in the tires today, same problem, just sounds like the tires so what can you do...
Old 08-19-2005, 12:45 PM
D-Bo's Avatar
D-Bo D-Bo is offline
get an alignment
Originally Posted by iVteC_PoWeR
to me when i really look at it hondas just too expensive and theres not much power even after you spend loads of money...
http://www.cardomain.com/id/dbo240
***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE***
Old 08-19-2005, 01:07 PM
NiSmO_zt's Avatar
hmm, but i didnt think there was any adjustment in the rear end? camber is fixed and the rest of the linkages are solid... hm
Old 08-19-2005, 01:19 PM
D-Bo's Avatar
how was your camber fixed?
Old 08-19-2005, 11:33 PM
NiSmO_zt's Avatar
no, its not fixed, it is fixed meaning that it isnt adjustable, (fixed, unadjustable, etc)
Old 08-20-2005, 03:33 AM
D-Bo's Avatar
oh.. ok.. make sure your tire pressure is normal (30-32 psi).. depending on the rims.. uhhh maybe something was bent during installation.. thats tough to say. if an alignment is completely out of the question then something must be caught, loose or bent.. or rubbing
Old 08-20-2005, 10:37 PM
NiSmO_zt's Avatar
im getting an alignment done this week, so ill let you know, thx
Old 08-21-2005, 09:52 PM
LaYzIeNoY LaYzIeNoY is offline
Send a message via AIM to LaYzIeNoY
can you tell if its both sides or just one side
i mean because if its just one side then somethign probably got messed up in the install
Old 08-23-2005, 06:36 PM
R.W.240's Avatar
R.W.240 R.W.240 is offline
Banned
There are eccentric bolts for camber and toe on the rear end.
Old 08-23-2005, 10:03 PM
monooxide's Avatar
monooxide monooxide is offline
Banned
Send a message via AIM to monooxide Send a message via MSN to monooxide
Ok...
Messed up on the install? How in the hell could you do that? its a rear coilover the easiest thing ive ever done...
Old 08-23-2005, 11:59 PM
240SXSlideStar's Avatar
240SXSlideStar 240SXSlideStar is offline
Dude, this guy came to me today and said he tried for 45 minutes to change the air filter in his Sonata and couldn't figure out how, so yes, someone ould mess up coilovers. :-P
-Jonathan
JDM Racing Motors inc
Montreal, Canada
www.jdmracingmotors.com
Old 08-24-2005, 02:02 AM
monooxide's Avatar
Banned
If hes..
If hes not dragging his rearend and the coilovers are still on odds are its right...
