Old 08-18-2005, 11:32 PM
Disney Dude Disney Dude is offline
Coax through firewall
I am in the process of installing a 2 meter amateur radio, but can't seem to find an easy place to run the coax thru the firewall from underneath the hood, to under the dash.
Any suggestions?
Thanks in advance.
Old 08-19-2005, 12:22 AM
kenny-1907's Avatar
kenny-1907 kenny-1907 is offline
Send a message via MSN to kenny-1907
Re: Coax through firewall
Maybe try the same grommet that the antenna wire goes through.
**2007 Avalanche LT. **
6" Pro Comp lift
305/55/20 BFG A/T KO'S
K&N FIPK GENII
Flo Pro V force muffler & 4" slash cut stainless tips
Color matched front and rear Bowties
3" polished stainless bull bar and Nerf bars
Old 08-19-2005, 09:29 AM
airjam18 airjam18 is offline
There's a grommet on the driver's side between the fender and the brake booster.......just pop a coat anger or thin screwdriver through it.......ig you look inside the cab by the drievr's side footwell the grommet is behind the emergency brake when its fully depressed......its about a foot up in that corner.....that's where my light wires come through.......or if you can go under the cab there's a grommet right underneath the drievrs side carpet....look under the truck and you'll see the rubebr grommet.......my cb antenna wires are run throught here....
Old 08-19-2005, 08:05 PM
Bubba14 Bubba14 is offline
Oops I gave wrong info as per the idiots at a local electronics (cb) installion shop. I will reroute mine asap. Pinched wires are not a good thing. I have also got some good info from this post. Thanks Bubba14
Old 08-19-2005, 10:24 PM
sportin83 sportin83 is offline
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
should be a rubber grommet in drivers under dash that goes by the booster, or there will be a clutch plate that can be drilled through also.
2002 CHEVY SILVERADO
more pics at http://www.cardomain.com/ride/2228127
Old 08-21-2005, 03:13 PM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
I also suggest using a grommet, anyone you can find. If you dont, you have a possibility of the truck rubbing through the coax and grounding it. This will burn your radio up really quick. I've replaced many in dump trucks and tractors that have done this.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 08-21-2005, 03:36 PM
Thanks for all the suggestions.
I used the rubber grommet in drivers under dash that goes by the booster for the coax, and used the opening between the hood and fender to run the power cables.
I appreciate all the suggestions.
Old 08-21-2005, 05:25 PM
Re: Re: Coax through firewall
you can drill a hole and go through the metal and use a plastic grommet that you can get from many stereo shops or possibly a auto parts store.
Old 08-21-2005, 05:27 PM
what do you mean you ran the power cable by the hood? like through the door jam? if so that is very unsafe! any wires that you run need to go through the firewall. if you go through the door or fender and that wire gets pinched or rubs through it will short out and catch fire.
Old 08-22-2005, 06:24 AM
Sorry guys, that is a mistake on my part.
Being an extra class amateur radio license holder, I am quite familar with electronics and circuitry.
The above post was an actual copy/paste from an email message I had received from someone on how they did it. I copied and pasted their email, and replied to them in an email message.
When I replied in the above message, I had (I thought) copied and pasted another reply that I had made, but my wireless keyboard evidently did not copy what I had thought, and I did not proof read the message prior to posting.
Both the coax, and power cables ARE run thru the firewall.
My mistake in the post...and thanks for the suggestions.
Old 08-22-2005, 10:36 AM
Re: Re: Re: Coax through firewall
i am glad to hear that you ran the wires safely, because i hate to hear about a car burning up because someone ran wires through an unsafe area and they melted and burnt car to ground.
