Old 08-18-2005, 10:26 PM
iamsodamnconfused iamsodamnconfused is offline
Jumping Gauges
Hey, does anyone have any problem with their gauges jumping from left, to right, then back to left when the car is first started? I've had this car for 2 years, and I just noticed that it does this. I just wanna know if this is normal or not. Oh yeah, its a 99 GASE.
Old 08-19-2005, 05:33 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Jumping Gauges
This is a common problem. I had a 99 that did this once started the problem went away. It can indicate a problem with the BCM or the trans speed sensor. As long as they settle down once the car is running don't worry about it at this point.
Old 08-20-2005, 01:46 PM
Re: Re: Jumping Gauges
Oh yeah, I guess I should should add that the speedo will not go all the way to 0 MPH, its stuck at 3-4MPH, but it will go to 0 once the car is shut off. Bad cluster maybe?
Old 08-20-2005, 02:55 PM
Pontiac Guy
Re: Jumping Gauges
Always a possiblilty. They do go bad from time to time especially the circuit board. You can get one from a wrecking yard and change it yourself for a few dollars.
