Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 08-18-2005, 09:18 PM
eurobeaner's Avatar
eurobeaner eurobeaner is offline
Send a message via MSN to eurobeaner
Help!!!
i have a 93 si del sol and i was goin down the highway today and it as at lik 7000rpmn and alll the sudden it lost all power and shut off and when i started it back up the motor was knocking and the check engine light was on and the oil light so i checked the oil and it would even read on the dip stick which is funny cause its never done that before so i put a quart in it and it still didnt so i put 4 more in it and filled it up and when i started it it stopped knocking but if you rev it to like 3 its knocks hard is that a rod bearing or something else i just need to know and what all i have to do to fix it like turn the crank or anything...thanx.
95 Civic EX
H&R sport springs
KYB AGX Struts
Energy Suspension Poly Bushings
15" black VSR's on nitto NT450 not-so extreme performance 205/50/15
CAI
http://www.cardomain.com/ride/2489240/1
Old 08-18-2005, 09:51 PM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
Re: Help!!!
Sounds like you may have thrown a rod. You will have to drop the oil pan to asess the damage.
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
