Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 08-18-2005, 07:57 PM
nds76 nds76 is offline
Odometer Messed Up on 2000 Sunfire
Well I have have this odometer problem for over a year now with my 2000 Sunfire. I still have not had it fixed. The digital display is all out of whack. Partial numbers, numbers disappear, they kinda just phase. Anybody else have had this problem? I'm not sure of the cost to have this fixed nor I don't know what is exactly the cause of this odd behavior. Please help...
David
Old 08-22-2005, 03:44 AM
Any thoughts or ideas?
Old 08-22-2005, 05:27 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Odometer Messed Up on 2000 Sunfire
If the display is bad like you state then you will need to replace it. There is probably a problem with the circuit board. If the speedometer is irratic then change the vehicle speed sensor located on the transmission.
Old 08-24-2005, 06:59 AM
Re: Re: Odometer Messed Up on 2000 Sunfire
The speedometer is fine, it's just the odometer that is messed up. It still keeps track of your miles but the digital display is what is irratic.
Old 08-24-2005, 08:52 AM
matt09524 matt09524 is offline
Send a message via MSN to matt09524
Your best bet is to likely replace the display and the board that controls it. If you have a background in electronics, You might be able to narrow the problem down even more and save yourself some money.
Old 09-06-2005, 01:48 PM
elmorock elmorock is offline
messed up odometer
we had same problem with ours ,we took it to GM dealer and they sent car to local stereo shop and they fixed it ,said it was burnt out lights on board it cost us 80 dollars canadain, took them about an hour to repair
Old 10-08-2005, 08:40 AM
tylyon tylyon is offline
Got the same problem with mine. I don't let it worry me. this way I am forced to stay on top of servicing the car by actually loking at the oil and seeing if it is dirty/cruddy etc. Actually look at the tires and check them for wear....etc.
